Calculate the length of pipes within a polygon
1102
04-15-2014 05:49 AM
ChristianDebono
I am calculating the total length of poly-lines (pipes) within a polygon. I am querying the layer and I am getting the result. The problem is that when I'm comparing the results with ArcMap I have some difference in the length. My code is:
featureLayer.on("click", function (evt) {
 map.graphics.clear();
 var highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol);
 map.graphics.add(highlightGraphic);
 var query = new Query();
 var queryTask = new QueryTask("feature layer with polylines");
 query.geometry = evt.graphic.geometry;
 query.returnGeometry = true;
 query.outSpatialReference = map.spatialReference;
 query.outFields = ["*"];
 queryTask.execute(query, function (results) {
  var lengthParams = new LengthsParameters();
  var pipesList = [];
  for (var i = 0; i < results.features.length; i++) {
   pipesList.push(results.features.geometry);
  lengthParams.polylines = pipesList;
  lengthParams.lengthUnit = GeometryService.UNIT_KILOMETER;
  geometryService.lengths(lengthParams);
dojo.connect(geometryService, "onLengthsComplete", outputDistance);
function outputDistance(result) {
    var total = 0;
    for (var i = 0; i < result.lengths.length; i++) {
        total += result.lengths;
    alert("Count: " + result.lengths.length + " Distance: "  + total.toFixed(2) + "km");
Am I doing something wrong with my code? Thanks
MuditAgarwal
hi,
Please try adding below line in your length parameters.
lengthParams.calculationType = "geodesic";
