Calcite Maps LayerList Issue
8419
10
12-20-2019 10:21 AM
MichaelSnook
Hi All
I am having an issue with Calcite maps Javascript and the 4.x LayerList widget using Android Chrome.  It seems that when the layer list widget has selectionEnabled: true - I am unable to turn the layers on/off and/or expand the layers in the widget.  I can reorder the layers without issue however.  This only seems to happen when the view is small as on a phone...it works fine when using a desktop browser.
Any ideas?
Thanks!
MichaelSnook
So, I've tested out the new LayerList functionality and, now I'm one for new improvements with everything -but, this new UI/UX is *really* confusing to say the least. The way the layers turn on and off is completely backwards from the TOCs in ArcMap/Pro.  It doesn't seem make sense to have an enabled button (the eyeball with the cross through it) to turn OFF a layer, and then the visible layers don't show an icon at all (unless I'm doing something wrong).
The old method was way more intuitive..checkboxes are even better.
Is there a way to choose how the UI/UX is rendered via the LayerList parameters?
Mike
