calcite-input-number with leading zero
4263
10
04-16-2025 02:55 PM
SebastianKrings
Using the calcite-input-number I would like to achieve leading zeros.
In the specific case the input ranges from 0 to 360 degrees.
So the following input should automatically show the exprected result within the input
0000
1001
10010
100100
360360
My input currently looks like this:
<calcite-input-number
            [min]="courseRange.min" [max]="courseRange.max" step="1"
            label="Course (in Degrees)"
            [value]="course()"
(calciteInputNumberChange)="refreshNumberChanged($event, course)"/>
refreshNumberChanged is used to write back the value into a signal. This replaces former ngModel syntax.
UndralBatsukh
https://github.com/Esri/calcite-design-system/issues/11987 - you should have access to this issue as long as you have github account
