Build a point with distance and degrees
3153
11
04-08-2013 05:31 AM
OlivierLevasseur
Hello everyone,
First of all, sorry for my english.
I am looking for how to build a point from another point according to a distance(meters) and a angle(degree).
Olivier
OlivierLevasseur
I finaly found a solution on the website http://www.movable-type.co.uk/scripts/latlong.html
Cheers for your help
Olivier
DavideLimosani
Hello everyone,
Olivier
Use trigonometry:
distance along x-axis = cos(angle)*distance
distance along y-axis = sin(angle)*distance
if you have a projected coordinate system add this values to your starting point.
OlivierLevasseur
Thank you for your answer.
I am worry that this method will not be precise enough as the earth is a sphere. But I could still have a try.
I keep you in touch.
Olivier
DavideLimosani
Olivier
Yeah, you are right. It depends on your purposes. But if you use a local projected coordinate system (UTM for example) it could be enough. Don't try it with Web Mercator 🙂
OlivierLevasseur
Hello,
it is working with the following method :
function buildPoint(point,angle, nav_long){
    var x = Math.cos(angle/180*Math.PI)*(nav_long*1/111111);
    var y = Math.sin(angle/180*Math.PI)*(nav_long*1/111111);
    newPoint = point.offset(x,y);
    return newPoint;
My problem is now the distance which is in meters. I found that 1 degree (latitude) = 111.11 km but it doesn't seem to work.
Olivier
OlivierLevasseur
My bad, this is working; I just have troubles with angles
DavideLimosani
Hey, that's why i said you that you should use a projected coordinate system, because it has coordinates in meters!
I think that using the equation 1 degree (latitude) = 111.11 km  is very dangerous.
If you are using a geographic coordinate system, I suggest you to use a geometry service to convert your point in a proper projected coordinates system, add to the new coordinates the new distances ( x and y ), and than convert again the new point to you map reference system.... maybe that there are other solutions less muddled but this is the only one that comes in my mind atm....
Davide
OlivierLevasseur
Hello Dlimos,
I tried what you advised me to do and this is perfectly working !! Thank you a lot !
To any people that might face this problem, this is the js function I used :
    var coord = esri.geometry.lngLatToXY(point.getLongitude(),point.getLatitude(),true);
    var ox = coord[0]+ Math.cos(angle/180*Math.PI)*nav_long;
    var oy = coord[1] + Math.sin(angle/180*Math.PI)*nav_long;
    var newPoint = new esri.geometry.Point(esri.geometry.xyToLngLat(ox,oy),new esri.SpatialReference({
        wkid:4326
    return newPoint;
OlivierL
DavideLimosani
Hello Dlimos,
        wkid:4326
    return newPoint;
OlivierL
Hey, esri.geometry.xyToLngLat and esri.geometry.lngLatToXY convert coordinates from wgs84 to webMercator and vice versa.
If you use Web Mercator u will get huge errors!
read this: http://blogs.esri.com/esri/arcgis/2010/03/05/measuring-distances-and-areas-when-your-map-uses-the-me...
use a geometry service to project your point in a local coordinate system please...
p.s. ty for removing the "correct answer" flag from my post  ahah 😉
OlivierLevasseur
Hey,
I though it was good because the angles fit but the length of the polyline are wrong (too small).
As I am a beginner in GIS, I will explain what I did and what I try to do. I hope you could hepl me to understand my mistakes.
I built a map of the harbor of le Havre (France) where boats are placed in.
I used google map to get the GPS location of the wharf which are the only locations I need to build everything.
I have to switch from google map to arcgis to get more accurate and more actual map.
I don't really understand which locale system to choose. Do you mean that I have to choose a wkid of spatialreference? Or should I build my own local system?
OlivierL
