Bugs in the directions widget
4819
03-30-2015 07:05 AM
JeffPace
Wanted to save some people time troubleshooting.  We recently have had two bugs logged for the directions widget
1. Reverse geocode not populating address back into widget even though it successfully completes when using local geocoder (works using AGO).
Defect ID: BUG-000084635
Synopsis: When using an ArcGIS Server geocode and route service, Directions widget displays coordinates instead of street addresses when either the destination stop or origin is dragged to a new location to recalculate the route or if new stops are added by clicking on the map.
Unfortunately, there is no workaround at this time.
2. Directions widget does not deactivate using mapClickActive=false even though deactivate() is deprecated
BUG-000086450 : directions widget does not deactivate even after directions.mapClickActive=false in ArcGIS API version 3.13
Workaround: Use directions.deactivate()
JeffPace
JeffPace
ShawnaErnst
Jeff,
Would you mind taking a look at my post?
Directions Widget: Close Stops and Optimize Order creates bad routes
Thank you,
Shawna
