Bug report
1595
01-27-2014 05:20 AM
ShaningYu
Honored Contributor
JeffPace
Why are you using 2.1 and 2.4 css?
The api is at 3.8
JeffPace
The api is at 3.8
ShaningYu
Honored Contributor
Using API 3.8 causes some bugs.  e.g. at
      dojo.require("dijit.dijit");
ShaningYu
Honored Contributor
It is actually the version conflict issue.  I will take Jeff's advice to use V3.8.  Thanks to Jeff.
JonathanUihlein
Please take some time to read the JSAPI documentation before making threads like this.
Thank you.
@Jeff Thank you for your insight. +1
