Bug Report on ArcGIS Server 10.2
3070
05-28-2015 07:28 AM
ShaningYu
Honored Contributor
This is a Bug Report on a detected bug for ArcGIS Server 10.2.  I loaded a FC onto ArcMap session.  One of the Fields (ACCESS_TYPE here) has subtype.   The attribute values can be viewed in ArcMap.  After I published it as a map service, the values of this field turn to its Subtype value (see the image attached).
