Bug? Map fires 'extent-changed' event upon a single mouse click in JS API v3.8
4689
7
02-27-2014 09:12 AM
Jay_Gregory
I am running into a problem with the JS API v3.8 in which the maps 'extent-change' event is fired with a single mouse click (not double or shift+click, just a simple click on the map), even though a single mouse click does not cause the map's extent to actually change.  Normally this isn't a problem unless you have a need to run some real code when the extent actually changes.  This behavior is unfortunately preventing my popup window from appearing, because I have a function attached to the 'extent-change' event which actually clears the feature layer.  But one click should just show the popup, and not fire the 'extent-change'.  UPDATE: this only seems to be affecting Chrome
Regardless, see the following code to reproduce in the simplest manner possible:
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>     <title>Simple Map</title>     <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">     <style>       html, body, #map {         height: 100%;         width: 100%;         margin: 0;         padding: 0;       }       body {         background-color: #FFF;         overflow: hidden;         font-family: "Trebuchet MS";       }     </style>     <script src="http://js.arcgis.com/3.8/"></script>     <script>       var map;       require(["esri/map",     "dojo/domReady!"],     function(    Map) {   map = new Map("map", {           basemap: "gray",          center: [-97, 38],           zoom: 5,           sliderStyle: "small"         });   map.on('extent-change', function(){console.log('extent changed');});          });     </script>   </head>   <body>     <div id="map"></div>   </body> </html>
JonathanUihlein
What version of Chrome are you seeing this issue in?
You are not seeing this issue in Firefox or IE, correct?
Also, is this desktop or mobile?
I am using: Version 33.0.1750.146 m.
Using your code, the 'extent-change' event fires once when the the map first loads, as expected.
However, the 'extent-change' event does not fire on a single map click.
I must drag or zoom for the 'extent-change' event to fire.
JeffPace
My guess is that chrome is more sensitive and may be interpreting a click as a drag
you could store the extent as a global, say,
oldextent
and then on "extent change"
if (oldextent==map.extent){
do nothing
}else{
oldextent=map.extent;
do stuff
JonathanUihlein
Jay_Gregory
hmmm, I don't see the behavior anymore.  It must have been fixed in a recent Chrome update.
JustinShepard
I'm seeing the same behavior in Chrome Version 34.0.1847.116 m.
It wasn't doing this before and sounds kind of sporadic.
ReneRubalcava
Esri Frequent Contributor
This happens in Chrome version 33.0.1750.154.
I'll have to double-check my version at home.
JustinShepard
I don't have a solution but I restarted my computer and now it is behaving as expected in Chrome (i.e. it's not trying to move the map every time that I click for an identify)
Drew
Sorry to wake this thread up almost 2 years later but I am having the same issue in Chrome version 48.0.2564.103 m
Using this thread, I was able to figure out a fix. I thought I would share a complete solution.
 var oldExtent = null;
//ON EXTENT CHANGE - UPDATE IF VISIBLE
on(this.map, "extent-change", function (event)
  var isEqual = false
  if (oldExtent != null)
  isEqual = geometryEngine.equals(oldExtent, event.extent);
  if (isEqual)
  console.log('EXTENT IS THE SAME');
  else
  console.log('EXTENT IS DIFFERENT');
  //SET OLD EXTENT
  oldExtent = event.extent;
Drew
