Bug in legend widget? Grouped legend values appear multiple times
10882
21
12-09-2010 01:45 PM
StephenLead
Honored Contributor
In ArcMap, create a Unique Values symbology, select multiple categories, then right-click and Group them.
Publish to ArcGIS Server and add as a dynamic map service. Using the new JS API version 2.1 legend widget, create a legend from this layer.
I'm finding that the grouped categories display multiple times. Eg, if the group consists of 3 individual categories, the (identical) symbol will appear in the legend 3 times.
Please let me know if you need any further information to reproduce this bug.
Steve
PS I have no idea why this title has a smiley face. Maybe that's another bug.
StephenLead
Honored Contributor
Any response from ESRI?
What's the best way to submit this as a bug report, given that I'm an EDN customer so don't have access to the full tech support?
Steve
KellyHutchins
Esri Notable Contributor
Do you have a test service that shows the problem?
Steve
StephenLead
Honored Contributor
Hi Kelly,
Unfortunately my server isn't yet accessible externally. But hopefully the description above is enough for you to recreate a similar service? Basically just use a Unique Values renderer, select a couple of classes, and choose Group.
Steve
JeffLegato
Kelly, We are experiencing this same issue and we don't have a outward facing server yet to show you.
We used the same steps as Steve, symbolize a layer and group in Symbology tab in Layer Properties.
Just thought you should know.
KellyHutchins
Steve and Jeff,
I updated a service to try and reproduce the problem but my legend doesn't display multiple items. The test service is public:
https://servicesbeta.esri.com/ArcGIS/rest/services/SanJuan/Trails/MapServer
The Trail Conditions layer has a unique value renderer and I grouped two of the items (maintenance and bridge). I also created a group layer (Trails, Regional Trail Conditions) just in case that was the issue.
I then modified the Legend Widget sample from the help to use the San Juan layer and in my tests there are no duplicate items. Is there something in your service that is substantially different?
StephenLead
Honored Contributor
Hi Kelly,
Your legend works fine for me, so I'm not sure what the problem is. Once our web server is outwardly facing I'll get you to try it and see if we can reproduce the problem.
Cheers,
Steve
KellyHutchins
Sounds good Steve, I'll try a few different tests as well to see if I can reproduce here as well.
Hi Kelly,
Cheers,
Steve
StephenLead
Honored Contributor
Hi Kelly,
Just a thought - I'm using an MSD file as input for the service. I've noticed that there's sometimes a difference when an MSD vs MXD file is used, which might be the case here?
Steve
MR
I'm getting this same problem Steve - did you manage to find a solution? I'm using MXD's so I don't think it's anything to do with that.
