[Bug] Feature disappears when zooming in
1285
11-25-2020 10:30 PM
ChrisShaw
Sometimes when zooming in features will disappear and not appear at the zoom level at all.
See gif https://i.imgur.com/mogzLTw.gif
Or features are just cutoff in the middle
This is using UniqueValueRenderer with png PictureMarkerSymbol
This  is only resolved by panning the map so the features are out of view and then panning back.
Edit. Forcefully refreshing through layer.refresh() works only if the refresh is called after 10 seconds. There seems to be some hard-coded caching that prevents immediate redraws.
huzeyfecoşkun
if its sceneveiw i mean 3D object can place under terrain so its dissapper. if its 2D map i dont know whats the problem.
mgeorge
@ChrisShaw if you can you provide a repro on codepen I can take a look. You can also try against /next and see if things are fixed. There were some fixes for clipping on tile boundaries that are in the 4.18 branch:
https://github.com/Esri/feedback-js-api-next
