Bug: 4.22 - 4.25. MapView - high-resolution screenshot not working
4027
12-20-2022 12:43 AM
KrzysztofNoga
high-resolution screenshot of a MapView stopped working since version 4.22 and still not fixed. In version 4.21 everything is fine. Below are some examples showing the problem.
Codepen sample 4.21 - https://codesandbox.io/s/elegant-violet-s10b7e?file=/index.html
Codepen sample 4.22 - https://codesandbox.io/s/cool-roman-vkyb42?file=/index.html
Codepen sample 4.25 - https://codesandbox.io/s/jovial-browser-hfu2ng?file=/index.html
UndralBatsukh
Hi there,
This issue is fixed and the fix will be installed for 4.26 version. You can test the fix by using our next version which this app already points to: https://codesandbox.io/s/jovial-browser-hfu2ng?file=/index.html
UndralBatsukh
Hi there,
Thank you for reporting this issue. Let me look into it and I will update you here.
KrzysztofNoga
Did you manage to find the bug?
UndralBatsukh
Hi there,
Yes we were able to reproduce the issue and I will update you here once we have a fix.
-Undral
UndralBatsukh
Hi there,
