Buffer not accurate
7425
27
12-20-2016 01:16 PM
by Anonymous User
Not applicable
Hi all,
I am trying to buffer a road segment 200' on each side but it seems like the buffer is not returning me anything accurate. The buffer on each side is like 520' as it is now. Maybe wkid?
var extent2 = new Extent({
                    "xmin": -121.11087086999999, "ymin": 38.517479534000074, "xmax": -119.95226375799996, "ymax": 39.068026806000034,
                    "spatialReference": { "wkid": 4326 }
                //Map
                map = new Map("map", {
                    basemap: "topo",
                    extent: extent2
featureLayer.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (targetGeometry) {
                            targetGeometry = graphicsUtils.getGeometries(featureLayer.getSelectedFeatures());
                            console.log(targetGeometry);
                            geometryService.union(targetGeometry, function (geometry) {
                                featureLayer.clearSelection();
                                //Buffer params
                                var params = new BufferParameters();
                                params.distances = [200];
                                params.unit = geometryService.UNIT_FOOT;
                                //Simplify features first
                                geometryService.simplify([geometry], function (simplifiedGeometries) {
                                    params.geometries = simplifiedGeometries;
                                    //do the buffer
                                    geometryService.buffer(params, showBuffer);
                            }, function (err) {
                                console.log(err);
by Anonymous User
Not applicable
Very strange,
When I get rid of the union to test only the buffer I get the following error
current code:
                                //Buffer params
                                params.outSpatialReference = map.spatialReference;
                                params.geodesic = true;
                                geometryService.simplify([targetGeometry], function (simplifiedGeometries) {
                                    //do the buffer
RobertScheitlin__GISP
Alex,
   If you do not union the selected geometries then you are you are passing an array of an array of geometries to the simplify.
targetGeomtry is an array then you wrap it in an array by doing this: [targetGeometry]
by Anonymous User
Not applicable
That is right. Ok, I am not too sure what I am missing on my buffer. Is the
simplify output line projected correctly and then messes up my buffer? I am
running out of idea.
On Tue, Dec 20, 2016 at 4:55 PM, Robert Scheitlin, GISP <geonet@esri.com>
Alex,
    What is the wkid of the lines that are selected.
by Anonymous User
Not applicable
Lines that are buffered are from road layer ID 3. spatial reference is as
here:
I am using the simplified geometry as param input for buffer as shown below:
feature that I select:
featureLayer = new FeatureLayer("
http://itas46:6080/arcgis/rest/services/Alex_test/TreemortalityAllLayers/MapServer/3
featureLayer.setAutoGeneralize(false);
featureLayer.setMaxAllowableOffset(0);
//simplify
geometryService.simplify(, function (simplifiedGeometries) {
params2.geometries =
//do the buffer
geometryService.buffer(params2,
showBuffer);
On Tue, Dec 20, 2016 at 5:40 PM, Robert Scheitlin, GISP <geonet@esri.com>
Alex,
   So did you try adding the
params.bufferSpatialReference = new SpatialReference({wkid:102003});
and not doing the union?
by Anonymous User
Not applicable
Yes, I tried. Same results.
current code:
                            //geometryService.union(targetGeometry, function (geometry) {
                                //Params buffer
                                var params2 = new BufferParameters();
                                params2.distances = [200];
                                params2.unit = geometryService.UNIT_FOOT;
                                params2.outSpatialReference = map.spatialReference;
                                params2.bufferSpatialReference = new SpatialReference({ wkid: 102100, latestWkid: 3857 });
                                params2.geodesic = true;
                                geometryService.simplify(targetGeometry, function (simplifiedGeometries) {
                                    params2.geometries = simplifiedGeometries;
                                    //do the buffer
                                    geometryService.buffer(params2, showBuffer);
                            //}, function (err) {
                            //    console.log(err);
Alex,
   Ok I am seeing this:
instead of what I recommended:
by Anonymous User
Not applicable
Ah ok. I just tried without success.
current code:
                                //Params buffer
                                params2.bufferSpatialReference = new SpatialReference({ wkid: 102003 });
                                    //do the buffer
Alex,
   Well I am running out of ideas then.
