Blinking symbol
6683
7
02-16-2012 05:24 AM
demdeberanz
Hi everybody, Is there the possibility to create a blinking symbol?and how?
Thank you for your reply.
derekswingley1
Check out the geolocation sample for an example of how to do this with CSS3:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/exp_geolocate.html
demdeberanz
Thank you my friend!;-)
JeffPace
Just a side note.  We had a blinking location on our maps. The overwhelming comment was
"How do i turn the &()&*(^_(^ heartbeat off"
People, overwhelmingly , HATED it.
derekswingley1
I'm happy to hear this. Animation for animation's sake usually isn't a good idea. Unless you have customers who absolutely demand it, you probably shouldn't do animated/pulsing map symbols.
JeffPace
This ^^^^^
We still use a pulsing symbol, but on the polygon not the centroid.  Plus it is disable-able with a cookie that remembers the preference.  We needed to keep it for situations where there is a large selection (say 10 polygons) but the info popup only relates to one of them.
demdeberanz
Hi everybody,
   and if I would like to blink only some kind of symbols? for example the SimpleMarkSymbol must blink and a CartographicLineSymbol not.
Thank you again.
MarkHoover
Have you considered putting a graphic on the map for a brief moment?
