Blank legend content
1568
07-05-2017 08:30 AM
GueniotFlorian
I would like to show a legend on my map with the value of each point, but my legend show only the title.
Anything is missing somewhere ?
Here is my code :
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<style>
  html, body, #viewDiv {
    padding: 0;
    margin: 0;
    height: 100%;
    width: 100%;
</style>
<title>Carte de lemmes</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
<script src="https://js.arcgis.com/4.3/"></script>
<script>
function getRandomColor() {
  var letters = '0123456789ABCDEF';
  var color = '#';
  for (var i = 0; i < 6; i++) {
    color += letters[Math.floor(Math.random() * 16)];
  return color;
require([
    "esri/views/MapView",
    "esri/Map",
    "esri/layers/FeatureLayer",
    "esri/layers/support/Field",
    "esri/geometry/Point",
    "esri/renderers/UniqueValueRenderer",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/widgets/Legend",
    "esri/request",
    "dojo/_base/array",
    "dojo/dom",
    "dojo/on",
    "dojo/domReady!"
  ], function(MapView, Map, FeatureLayer, Field, Point,
UniqueValueRenderer, SimpleMarkerSymbol, Legend, esriRequest,
    arrayUtils, dom, on
// Création de la couche de points
var fields = [
alias: "ObjectID",
type: "oid"
alias: "lemme",
type: "string"
alias: "formePhonique",
type: "string"
alias: "commune",
type: "string"
alias: "question",
type: "string"
var pTemplate = {
        title: "{question}",
        content: [{
          type: "fields",
          fieldInfos: [{
            fieldName: "lemme",
            label: "Lemme",
            visible: true
            fieldName: "formePhonique",
            label: "Forme phonique",
            visible: true
            fieldName: "commune",
            label: "Commune",
            visible: true
var features = [{geometry: new Point({
    x: 9.123337,
y: 42.474312,
  attributes: {
    ObjectID: 7885,
lemme: "tumbà",
formePhonique: "tumb'a",
commune: "Moltifao",
question: "'tuer' (le cochon)"
},{geometry: new Point({
    x: 9.011969,
y: 41.640460,
  attributes: {
    ObjectID: 34741,
lemme: "pulsà",
formePhonique: "pulz'a",
commune: "Granace",
    x: 9.253651,
y: 41.592664,
  attributes: {
    ObjectID: 36089,
lemme: "tumbà",
commune: "Porto Vecchio",
      var map = new Map({
      basemap: "gray"
  var view = new MapView({
      container: "viewDiv"// Reference to the DOM node that will contain the view
      center: [9.15892639, 42.183238],
      zoom: 9,
      map: map               // References the map object created in step 3
    var tumbà = new SimpleMarkerSymbol({
          color: getRandomColor(),
          width: 10,
          style: "solid"
var pulsà = new SimpleMarkerSymbol({
          width: 10,
          style: "solid"
    var defaultSymb = new SimpleMarkerSymbol({
        color: "#123456",
        width: 10,
        style: "solid"
    var myrenderer = new UniqueValueRenderer({
     defaultSymbol: defaultSymb,
      defaultLabel: "Other major roads",
      field: "lemme",
      visualVariables: [
         type: "size",
         field: "lemme"
      uniqueValueInfos: [
        value: "tumbà", // code for interstates/freeways
        symbol: tumbà,
        label: "tumbà"
        value: "pulsà", // code for interstates/freeways
        symbol: pulsà,
        label: "pulsà"
    var lyr = new FeatureLayer({
source: features,
        fields: fields,
        objectIdField: "ObjectID",
        geometryType: "point",
        renderer: myrenderer,
        spatialReference: {
            wkid: 4326
        popupTemplate: pTemplate,
        legendEnabled: true,
    map.add(lyr);
var legend = new Legend({
        view: view,
        layerInfos: [{
          layer: lyr,
          title: "'tuer' (le cochon)"
    view.ui.add(legend, "bottom-left");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
UndralBatsukh
You are setting wrong symbol style for SimpleMarkerSymbol. Please change the style as documented here and should work:
SimpleMarkerSymbol | API Reference | ArcGIS API for JavaScript 4.4
  color: "#123456",
  width: 10,
  style: "circle"
UndralBatsukh
  color: "#123456",
  width: 10,
  style: "circle"
GueniotFlorian
Now it's working.
Thanks!
