Bing Map showing blank
4707
11
09-19-2015 07:44 AM
JulieBiju
Hi All,
Urgent ...Pls help me.
Bing map is not loading in my application .It is showing blank screen.
Rest all maps working fine.Pls Help.Bing map key I used is correct
java script used below
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="Map.aspx.vb" Inherits="Default2" %>
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
    <head runat="server">
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
        <meta http-equiv="X-UA-Compatible" content="IE=7" />
        <!--The viewport meta tag is used to improve the presentation and behavior of the samples
        on iOS devices-->
        <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
        <title>Google Maps Layer in ArcGIS JS API</title>
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css"/>
    <style type="text/css">
        html, body, #mapDiv{
        padding: 0;
        margin: 0;
        height: 100%;
            z-index: -1;
        .auto-style3 {
            height: 20px;
        .auto-style6 {
            height: 2%;
            width: 279px;
        .auto-style7 {
            width: 279px;
        #TxtAltareeqEng {
            width: 55px;
        #TxtAltareeqEng0 {
            width: 55px;
    </style>
     <script type="text/javascript">
         var djConfig = {
             parseOnLoad: true,
             baseUrl: './',
             modulePaths: {
                 // if use local copy, make sure the path reference is relative to 'baseUrl', e.g.:
                 //'agsjs': '../build/agsjs'
                 // use absolute path for online version. Note sometimes googlecode.com can be slow.
                 'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/1.05/build/agsjs'
        </script>
        <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4">
        </script>
         <script type="text/javascript" src="Scripts/gmapslayer_compiled.js">
        </script>
        <script src="Scripts/jquery-2.1.1.js" type="text/javascript"></script>
            window.onerror = function (msg, url, linenumber) {
                alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
                return true;
            dojo.require("esri.map");
            dojo.require("dijit.form.Button");
            dojo.require("dijit.layout.BorderContainer");
            dojo.require("dijit.layout.ContentPane");
            //dojo.require("agsjs.layers.GoogleMapsLayer");
            dojo.require("esri.layers.graphics");
            dojo.require("esri.virtualearth.VETiledLayer");
            var map;
            var streetMap, esriTopo, gMap, BingLayer;
            var graphicsLayer;
            var Map1, Map2;
            var lastposdate  = "";
            var DoorOpenClose = 'NO';
            function init() {
                var initExtent = new esri.geometry.Extent({
                    "xmin": -14628212,
                    "ymin": 714227,
                    "xmax": 7718305,
                    "ymax": 9832858,
                    "spatialReference": {
                        "wkid": 102100
                //alert('init');
                map = new esri.Map("mapDiv", {
                    extent: initExtent,
                    logo: true
                Map1 = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
                Map2 = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServ...";
                streetMap = new esri.layers.ArcGISDynamicMapServiceLayer(Map1, {
                map.addLayer(streetMap);
                esriTopo = initLayer(Map2, "esriTopo");
                BingLayer = new esri.virtualearth.VETiledLayer({
                    bingMapsKey: "A......",
                    mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
                map.addLayer(BingLayer);
                gMap = new gmaps.GoogleMapsLayer({
                    visible: false,
                map.addLayer(gMap);
                graphicsLayer = new esri.layers.GraphicsLayer();
                map.addLayer(graphicsLayer);
                var resizeTimer;
                dojo.connect(map, 'onLoad', function (theMap) {
                    dojo.connect(dijit.byId('map'), 'resize', function ()
                    { //resize the map if the div is resized
                        clearTimeout(resizeTimer);
                        resizeTimer = setTimeout(function () {
                            map.resize();
                            map.reposition();
                        }, 500);
            function initLayer(url, id) {
                var layer = new esri.layers.ArcGISDynamicMapServiceLayer(url, {
                    visible: false
                map.addLayer(layer);
              return layer;
            function changeMap(layers) {
                hideImageTiledLayers(layers);
                for (var i = 0; i < layers.length; i++) {
                    layers.show();
                    alert(layers.id);
            function hideImageTiledLayers(layers) {
                  for (var j = 0, jl = map.layerIds.length; j < jl; j++) {
                    var layer = map.getLayer(map.layerIds);
                    if (dojo.indexOf(layers, layer) == -1) {
                        layer.hide();
                dojo.addOnLoad(init)
        </script>
</head>
<body class="claro"  >
<form id="form1" runat="server">
    <div style="width: 100%; height: 100%">
                <table id="Tablecontrols0"   style="font-size: 15px; z-index: 101;
            background-color: #5B748B; width: 100%; height: 100%;">
            <tr style="font-family: Times New Roman">
                <td style="border-style: none; background-color: #496277; "
                    valign="top" class="auto-style6" >
                     </td>
                <td align="left"   style="border-style: none; background-color: #496277; height: 2%;"
                    valign="top" class="auto-style3" >
                     </td>
            </tr>
                <td style="border-style: none;"
                    valign="top" bgcolor="#496277"   >
                     </td>
                <td style="border-style: none; background-color: white; height: 500px;"
                    valign="top" id="td11" >
            <div id="mapDiv" runat ="server"  dojotype="dijit.layout.ContentPane" region="center"
                style="border:1px solid #000; visibility: visible; height: 100%; ">
                <br />
                <br />
            </div>
            <div id="buttons" style="position:absolute; right:75px; top:83px; z-Index:999;">
                <button dojoType="dijit.form.Button"   onClick="changeMap([streetMap]);">
                    Al Tareeq(EN)</button>
                <button dojoType="dijit.form.Button" onClick="changeMap([esriTopo]);">
                    Al Tareeq(AR)
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('roadmap')">
                    Google Street
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('satellite')">
                    Google Statellite
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('hybrid')">
                    Google Hybrid
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([gMap]);gMap.setMapTypeId('terrain')">
                    Google Terrain
                </button>
                <button dojoType="dijit.form.Button" onClick="changeMap([BingLayer]);BingLayer.setMapStyle('esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL');">
                    Bing Aerial
                </button>
                    Bing Aerial with labels
                </button>
                  <button dojoType="dijit.form.Button" onClick="changeMap([BingLayer]);">
                   Roads
                </button>
            </div>   </td>
            </tr>
            </table>
     </div>
        </form>
</body>
</html>
ChrisSmith7
Might be for the best. In my experience, there were some draconian TOS issues with using Google Maps. If Esri is giving Bing samples, they have probably already vetted the usage as a background map.
JulieBiju
Chris,
Thank A Lot.
