Best way of bringing layerlist widgets content to a Dialolg?
1907
01-29-2018 03:57 AM
AnnCrystal
In this ESRI sample:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Layer List Dijit</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.23/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/css/esri.css">
<style>
html, body, .container, #map {
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
    font-family: "Open Sans";
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
  background-color: #fff;
.esriLayerList .esriList{
    border-top:none;
.esriLayerList .esriTitle {
  border-bottom:none;
.esriLayerList .esriList ul{
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="https://js.arcgis.com/3.23/"></script>
<script>
require([
    "esri/arcgis/utils",
    "esri/dijit/LayerList",
    "dijit/layout/BorderContainer",
    "dijit/layout/ContentPane",
    "dojo/domReady!"
], function(
    arcgisUtils,
    LayerList
    //Create a map based on an ArcGIS Online web map id
    arcgisUtils.createMap("f63fed3f87fc488489e27c026fa5d434", "map").then(function(response){
        var myWidget = new LayerList({
           map: response.map,
           layers: arcgisUtils.getLayerList(response)
        },"layerList");
        myWidget.startup();
</script>
</head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false">
<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
    <div id="layerList"></div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
How can I pull the result from "layerList" DOM element to a dijit Dialog (in js 3.23) instead of using a ContentPane?
Thanks
-Ann
RobertScheitlin__GISP
Ann,
   Here is a way to have a movable and resizable floating pane:
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.23/dojox/layout/resources/FloatingPane.css" />
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.23/dojox/layout/resources/ResizeHandle.css" />
  <style>
    html,
    body,
    .container,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #layerList {
      padding: 0;
      margin:0;
      height: 100%;
      width: 100%;
    #map {
      padding: 0;
    .esriLayer {
    .dojoxFloatingPaneTitle {
      background-color: #217bba;
      background: -webkit-linear-gradient(#fff, #217bba, #217bba, #217bba, #217bba, #217bba, #217bba, #1f6291);
      background: -moz-linear-gradient(#fff, #217bba, #217bba, #217bba, #217bba, #217bba, #217bba, #1f6291);
      background: linear-gradient(#fff, #217bba, #217bba, #217bba, #217bba, #217bba, #217bba, #1f6291);
      color: #fff;
      font-weight: bolder;
    /* .dojoxDock {
      display: none;
    .dojoxFloatingPaneTitle,
    .dojoxFloatingPane {
      border: none;
    .dojoxFloatingPaneContent {
      padding: 0;
    #wfp {
      padding: 8px;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script>
    var fp;
    require([
      "dojox/layout/FloatingPane",
      "dojo/domReady!"
    ], function(
      arcgisUtils,
      LayerList,
      FloatingPane
      arcgisUtils.createMap("f63fed3f87fc488489e27c026fa5d434", "map").then(function(response) {
        fp = new FloatingPane({
          title: "Layer List",
          closable: false,
          resizable: true,
          dockable: true,
          style: "position:absolute;top:250px;left:350px;width:300px;height:300px;",
        }, "divFloatingPane");
        fp.startup();
          map: response.map,
        }, "layerList");
        myWidget.startup();
  </script>
</head>
  <div class="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false">
  </div>
  <div id="divFloatingPane">
  </div>
</body>
</html>
Ann,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    .container,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #layerList {
      padding: 0;
      margin:0;
      height: 100%;
      width: 100%;
    #map {
      padding: 0;
    .esriLayer {
      color: #fff;
    /* .dojoxDock {
      display: none;
      border: none;
      padding: 0;
    #wfp {
      padding: 8px;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script>
    var fp;
    require([
      "dojo/domReady!"
    ], function(
      arcgisUtils,
      LayerList,
      FloatingPane
          closable: false,
          resizable: true,
          dockable: true,
        fp.startup();
          map: response.map,
        }, "layerList");
        myWidget.startup();
  </script>
</head>
  </div>
  </div>
</body>
</html>
AnnCrystal
Awesome-Thanks Robert. I was banging my head on Dijit Dialog which didn't work. I was confused about whether to use floating pane as it was marked as an experimental floating window. and Dojo has a suggestion for Dijit/Dialog.
