Best practice to show load icon
3644
10-03-2014 08:21 AM
LeiZhong
I have a base map, and then load a large csvLayer (over 5,000points) on top of it. I'd like to show the load icon until the csvLayer is fully loaded. How would I setup the event? On layer load or map load?  I'm new to AMD style and still not very familiar the javascript api. Some ESRI examples have:
dojo.connect(map, "onUpdateEnd", updateEnd);
So I did
map.on("onUpdateEnd", hideLoading")   (on line 60 of attached file)
but the hideLoading is never triggered. Should I do it on a layer instead of layer? Thanks!
Tags (1)
KenBuja
MVP Esteemed Contributor
When you use "on" style of events in AMD, the events have a different name. You would use "update-end" instead of "onUpdateEnd".
This sentence in the Events page explains it.
The other important difference, is event names. New on style event names are lowercased, words are hyphen separated, and there is no "on" prefix.
KenBuja
LeiZhong
Yup, that did it. Thanks!
