Below code i taken from sample code which is available ,in this code i have to customized to show how many numbers of polygons(buildings) are selected in selected area
2003
07-10-2019 11:46 PM
AnupamSharma
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>SceneLayerView - query statistics by geometry - 4.12</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-ui-top-right {
max-height: 100%;
#queryDiv,
#resultDiv {
min-width: 250px;
font-size: 14px;
padding: 10px;
display: none;
overflow-y: auto;
overflow-x: hidden;
.geometry-options {
display: flex;
flex-direction: row;
.geometry-button {
flex: 1;
border-style: solid;
border-width: 1px;
border-image: none;
.geometry-button-selected {
background: #4c4c4c;
color: #fff;
#bufferNum {
width: 90%;
margin: 2.5em auto 0;
.count {
white-space: nowrap;
font-size: 14px;
font-weight: bold;
display: inline-block;
</style>
<!-- Load the Chart.js library -->
<script src="https://cdnjs.cloudflare.com/ajax/libs/Chart.js/2.8.0/Chart.min.js"></script>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.12/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.12/"></script>
<script>
require([
"esri/WebScene",
"esri/views/SceneView",
"esri/layers/GraphicsLayer",
"esri/widgets/Sketch/SketchViewModel",
"esri/widgets/Slider",
"esri/geometry/geometryEngine",
"esri/Graphic",
"esri/core/promiseUtils"
], function(
WebScene,
SceneView,
GraphicsLayer,
SketchViewModel,
Slider,
geometryEngine,
Graphic,
promiseUtils
// Load webscene and display it in a SceneView
const webscene = new WebScene({
portalItem: {
// create the SceneView
const view = new SceneView({
container: "viewDiv",
map: webscene
window.view = view;
// add a GraphicsLayer for the sketches and the buffer
const sketchLayer = new GraphicsLayer();
const bufferLayer = new GraphicsLayer();
view.map.addMany([bufferLayer, sketchLayer]);
let sceneLayer = null;
let sceneLayerView = null;
let bufferSize = 0;
// Assign scene layer once webscene is loaded and initialize UI
webscene.load().then(function() {
sceneLayer = webscene.layers.find(function(layer) {
return layer.title === "Helsinki textured buildings";
sceneLayer.outFields = ["buildingMaterial", "yearCompleted"];
view.whenLayerView(sceneLayer).then(function(layerView) {
sceneLayerView = layerView;
queryDiv.style.display = "block";
view.watch("updating", function(updating) {
if (!updating) {
runQuery();
view.ui.add([queryDiv], "bottom-left");
view.ui.add([resultDiv], "top-right");
// use SketchViewModel to draw polygons that are used as a query
let sketchGeometry = null;
const sketchViewModel = new SketchViewModel({
layer: sketchLayer,
defaultUpdateOptions: {
tool: "reshape",
toggleToolOnClick: false
view: view
sketchViewModel.on("create", function(event) {
if (event.state === "complete") {
sketchGeometry = event.graphic.geometry;
runQuery();
sketchViewModel.on("update", function(event) {
if (event.state !== "cancel" && event.graphics.length) {
sketchGeometry = event.graphics[0].geometry;
runQuery();
// draw geometry buttons - use the selected geometry to sktech
document
.getElementById("point-geometry-button")
.addEventListener("click", geometryButtonsClickHandler);
document
.getElementById("line-geometry-button")
document
.getElementById("polygon-geometry-button")
function geometryButtonsClickHandler(event) {
const geometryType = event.target.value;
clearGeometry();
sketchViewModel.create(geometryType);
const bufferNumSlider = new Slider({
container: "bufferNum",
min: 0,
max: 500,
steps: 1,
labelsVisible: true,
precision: 0,
labelFormatFunction: function(value, type) {
return value.toString() + "m";
values: [0]
// get user entered values for buffer
bufferNumSlider.on("value-change", bufferVariablesChanged);
function bufferVariablesChanged(event) {
bufferSize = event.value;
runQuery();
// Clear the geometry and set the default renderer
document
.getElementById("clearGeometry")
.addEventListener("click", clearGeometry);
function clearGeometry() {
sketchViewModel.cancel();
sketchLayer.removeAll();
bufferLayer.removeAll();
clearHighlighting();
clearCharts();
resultDiv.style.display = "none";
// set the geometry query on the visible SceneLayerView
var debouncedRunQuery = promiseUtils.debounce(function() {
if (!sketchGeometry) {
return;
resultDiv.style.display = "block";
updateBufferGraphic(bufferSize);
return promiseUtils.eachAlways([
queryStatistics(),
updateSceneLayer()
function runQuery() {
debouncedRunQuery().catch((error) => {
if (error.name === "AbortError") {
return;
console.error(error);
// Set the renderer with objectIds
var highlightHandle = null;
function clearHighlighting() {
if (highlightHandle) {
highlightHandle.remove();
function highlightBuildings(objectIds) {
// Remove any previous highlighting
const objectIdField = sceneLayer.objectIdField;
document.getElementById("count").innerHTML = objectIds.length;
highlightHandle = sceneLayerView.highlight(objectIds);
// update the graphic with buffer
function updateBufferGraphic(buffer) {
// add a polygon graphic for the buffer
if (buffer > 0) {
var bufferGeometry = geometryEngine.geodesicBuffer(
sketchGeometry,
buffer,
"meters"
if (bufferLayer.graphics.length === 0) {
bufferLayer.add(
new Graphic({
geometry: bufferGeometry,
symbol: sketchViewModel.polygonSymbol
} else {
bufferLayer.graphics.getItemAt(0).geometry = bufferGeometry;
} else {
function updateSceneLayer() {
const query = sceneLayerView.createQuery();
query.geometry = sketchGeometry;
query.distance = bufferSize;
return sceneLayerView.queryObjectIds(query).then(highlightBuildings);
var yearChart = null;
var materialChart = null;
function queryStatistics() {
const statDefinitions = [
onStatisticField:
"CASE WHEN buildingMaterial = 'concrete or lightweight concrete' THEN 1 ELSE 0 END",
outStatisticFieldName: "material_concrete",
statisticType: "sum"
onStatisticField:
"CASE WHEN buildingMaterial = 'brick' THEN 1 ELSE 0 END",
outStatisticFieldName: "material_brick",
onStatisticField:
"CASE WHEN buildingMaterial = 'wood' THEN 1 ELSE 0 END",
outStatisticFieldName: "material_wood",
onStatisticField:
"CASE WHEN buildingMaterial = 'steel' THEN 1 ELSE 0 END",
outStatisticFieldName: "material_steel",
onStatisticField:
"CASE WHEN buildingMaterial IN ('concrete or lightweight concrete', 'brick', 'wood', 'steel') THEN 0 ELSE 1 END",
outStatisticFieldName: "material_other",
onStatisticField:
"CASE WHEN (yearCompleted >= '1850' AND yearCompleted <= '1899') THEN 1 ELSE 0 END",
outStatisticFieldName: "year_1850",
onStatisticField:
"CASE WHEN (yearCompleted >= '1900' AND yearCompleted <= '1924') THEN 1 ELSE 0 END",
outStatisticFieldName: "year_1900",
onStatisticField:
"CASE WHEN (yearCompleted >= '1925' AND yearCompleted <= '1949') THEN 1 ELSE 0 END",
outStatisticFieldName: "year_1925",
onStatisticField:
"CASE WHEN (yearCompleted >= '1950' AND yearCompleted <= '1974') THEN 1 ELSE 0 END",
outStatisticFieldName: "year_1950",
onStatisticField:
"CASE WHEN (yearCompleted >= '1975' AND yearCompleted <= '1999') THEN 1 ELSE 0 END",
outStatisticFieldName: "year_1975",
onStatisticField:
"CASE WHEN (yearCompleted >= '2000' AND yearCompleted <= '2015') THEN 1 ELSE 0 END",
outStatisticFieldName: "year_2000",
query.outStatistics = statDefinitions;
return sceneLayerView.queryFeatures(query).then(function(result) {
const allStats = result.features[0].attributes;
updateChart(materialChart, [
allStats.material_concrete,
allStats.material_brick,
allStats.material_wood,
allStats.material_steel,
allStats.material_other
updateChart(yearChart, [
allStats.year_1850,
allStats.year_1900,
allStats.year_1925,
allStats.year_1950,
allStats.year_1975,
allStats.year_2000
}, console.error);
// Updates the given chart with new data
function updateChart(chart, dataValues) {
chart.data.datasets[0].data = dataValues;
chart.update();
function createYearChart() {
const yearCanvas = document.getElementById("year-chart");
yearChart = new Chart(yearCanvas.getContext("2d"), {
type: "horizontalBar",
data: {
labels: [
"1850-1899",
"1900-1924",
"1925-1949",
"1950-1974",
"1975-1999",
"2000-2015"
datasets: [
label: "Build year",
backgroundColor: "#149dcf",
stack: "Stack 0",
data: [0, 0, 0, 0, 0, 0]
options: {
responsive: false,
legend: {
display: false
title: {
display: true,
text: "Build year"
scales: {
xAxes: [
stacked: true,
ticks: {
beginAtZero: true,
precision: 0
yAxes: [
stacked: true
function createMaterialChart() {
const materialCanvas = document.getElementById("material-chart");
materialChart = new Chart(materialCanvas.getContext("2d"), {
type: "doughnut",
data: {
labels: ["Concrete", "Brick", "Wood", "Steel", "Other"],
datasets: [
backgroundColor: [
"#FD7F6F",
"#7EB0D5",
"#B2E061",
"#BD7EBE",
"#FFB55A"
borderWidth: 0,
data: [0, 0, 0, 0, 0]
options: {
responsive: false,
cutoutPercentage: 35,
legend: {
position: "bottom"
title: {
display: true,
text: "Building Material"
function clearCharts() {
updateChart(materialChart, [0, 0, 0, 0, 0]);
updateChart(yearChart, [0, 0, 0, 0, 0, 0]);
document.getElementById("count").innerHTML = 0;
createYearChart();
createMaterialChart();
</script>
</head>
<body>
<div id="viewDiv"></div>
<div id="queryDiv" class="esri-widget">
<b>Query by geometry</b><br />
<br />Draw a geometry to query by:
<div class="geometry-options">
<button
class="esri-widget--button esri-icon-map-pin geometry-button"
id="point-geometry-button"
value="point"
title="Query by point"
></button>
<button
class="esri-widget--button esri-icon-polyline geometry-button"
id="line-geometry-button"
value="polyline"
title="Query by line"
></button>
<button
class="esri-widget--button esri-icon-polygon geometry-button"
id="polygon-geometry-button"
value="polygon"
title="Query by polygon"
></button>
</div>
<br />
<div class="tooltip">
<label for="bufferNum">Set a geometry buffer size:</label>
<div id="bufferNum"></div>
</div>
<br />
<button class="esri-button" id="clearGeometry" type="button">
Clear
</button>
</div>
<div id="resultDiv" class="esri-widget">
<div class="count">
Selected Buildings:
<div class="count" id="count">0</div>
</div>
<div class="charts">
<div>
<canvas id="year-chart" height="250" width="260" />
</div>
<div>
<canvas id="material-chart" width="250" height="300" />
</div>
</div>
</div>
</body>
</html>
SaschaBrunnerCH
Hello Anupam
The count is already in the sample at the top of the panel:
For better readability you can use https://community.esri.com/docs/DOC-8691-posting-code-with-syntax-highlighting-on-geonet for the code.
AnupamSharma
Than you so much
