Basemap Gallery Update Issues
8266
16
12-22-2014 01:40 PM
StevenGraf1
I noticed 3.12 came with some new basemaps.
1.  Terrain with Labels draws on top of my layers I have added to the map.
2.  If I switch to USGS National Map, it doesn't load.  After a little bit of switching between maps, my layers disappear from my map entirely and can't turn them back on with checkbox.
Here is an older unsecured application this is happening on.  I noticed on a version 3.8 AMD application I have it happens as well.
Anyone else experiencing the issue?
StevenGraf1
I suppose I need to update my apps to 3.12 release to get full support of the extra basemaps.  Is there a way to specify which arcgis basemaps we want to show?
KenBuja
MVP Esteemed Contributor
The USGS National map appears properly in the sample. As for your first question, is the problem that the labels are being drawn in front of your other layers? I noticed that happening in 3.11 also. This happens with the Oceans basemap too. Take a look at this example which shows the map's layers (including the basemap)
StevenGraf1
The USGS National Map doesn't work in my older applications.
For the first question, The labels, roads and water features seem to draw on top of my layers.
KenBuja
Yes, that happened in 3.11 and now in 3.12 (here‌).
StevenGraf1
I take it, it was designed that way?
I'm more worried about my layers disappearing and not being able to add them back in.  It takes a little effort to make this happen in my v3.8 application.  I will try and get it updated to 3.12 as soon as I can.
Thanks!
Steven
KenBuja
If it was designed that way, it's a mistake, in my eyes. The labels are one thing, but the line and polygon features shouldn't be placed on top of your features.
I'm not sure what you mean about your layers disappearing, though.
StevenGraf1
Ya, I would see it as a mistake also.  I will try and reproduce the steps to make my layers disappear by switching basemaps and post back soon.
Thanks!
StevenGraf1
What's happening is the basemap gallery widget is timing itself out when it requests the USGS National Map.  This causes all the layers that were in the map to disappear and I have to refresh the page to bring them back in.
StevenGraf1
Here is the error I am getting:
Mixed Content: The page at 'https://mysite.html' was loaded over HTTPS, but requested an insecure script 'http://basemap.nationalmap.gov/arcgis/rest/services/USGSTopo/MapServer?f=json&callback=dojo.io.scrip...'. This request has been blocked; the content must be served over HTTPS.
The rest endpoint has an secured service but the basemap gallery is only pulling the unsecured service.  Is there a way to fix this?
Thanks
