basemap-gallery and arcgis-map components and USA style
2173
05-19-2025 07:58 AM
GaryB
My organization’s AGOL is configured to use the U.S. style (e.g. Gulf of America), but I see Gulf of Mexico on my initial map.  When I change my basemap (via the basemap gallery) it shows Gulf of America from then on.  How does one configure the arcgis-map component so the initial basemap also honors the required style?
Unrelated to the above, the basemap-gallery component has about 35 maps by default.  I struggled a bit trying to specify a subset of basemaps to present the user with but I was not successful and would appreciate any code snippets (I think it’s in the view model but I couldn’t get it working).
ReneRubalcava
Esri Frequent Contributor
You can accomplish this by leaving the item-id and basemap empty attributes on the arcgis-map component, then creating your own map/basemap as needed.
https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/how-to-use-a-basemap-with-a-speci...
  <arcgis-map>
  </arcgis-map>
  <script type="module">
    const VectorTileLayer = await $arcgis.import("@arcgis/core/layers/VectorTileLayer.js");
    const ArcGISMap = await $arcgis.import("@arcgis/core/Map.js");
    const Basemap = await $arcgis.import("@arcgis/core/Basemap.js");
    const mapElement = document.querySelector("arcgis-map");
    // create a VectorTileLayer from a style URL
    const mapBaseLayer = new VectorTileLayer({
      url: "https://basemapstyles-api.arcgis.com/arcgis/rest/services/styles/v2/styles/arcgis/topographic",
      // set the worldview as a custom parameter
      customParameters: {
        worldview: "unitedStatesOfAmerica"
    const basemap = new Basemap({
      // set the VTL as the basemap layer
      baseLayers: [mapBaseLayer]
    mapElement.map = new ArcGISMap({
      basemap
  </script>
https://codepen.io/odoe/pen/dPPEvgY?editors=1000
ReneRubalcava
For your basemap gallery question, you want to create a PortalBasemapSource.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-BasemapGallery-support-Po...
You can provide a query for basemaps to load.
This sample shows it's use.
https://developers.arcgis.com/javascript/latest/sample-code/basemaps-portal/
GaryB
Thanks for the input @ReneRubalcava, with your suggestion I was able to figure out how to subset the basemaps in the gallery, however, with regards to the US worldmap style, now I am having the opposite problem where I can get the first map to show the US perspective, but the gallery basemaps revert to the non-US perspective.  I've posted my test application at https://github.com/VolpeUSDOT/basemap-sytle.  Thanks!
ReneRubalcava
Looking at this blog post, it looks like you would need to set it up in your organization.
https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/esri-vector-basemaps-for-unite...
I haven't done this, but you might be able to go through each one and assign the region in Map Viewer.
GaryB
Our organization is set up for the United States and all of our basemaps in AGOL show up the way I need them to, it just doesn't work in my custom application.  In my sample code (see GitHub link in my previous post) I iterated through the basemaps and tried loadedBasemap.style.worldview = 'unitedStatesOfAmerica' but that didn't work either.  I'm at a bit of a loss as to what else to try.
