avoid drag zoom
2992
01-24-2017 12:04 PM
JasonBaddley
We are trying to understand how you can override the default behavior of shift+drag so that is doesn't zoom-in. We are implementing drag filtering where the user uses shift+drag to create a rectangle on the map.
FC_Basson
RickeyFight
JasonBaddley
This was very helpful, thank you. I can't seem to find an equivalent in 4.2. And when I try it the 'load' event never fires.
RobertScheitlin__GISP
Jason,
   Be sure to include a tag for 4.2 or something in your text letting us know you are working with 4.2.
There is no equivalent for 4.2 yet.
JasonBaddley
Meaning no docs for 4.2 or no implementation?
FC_Basson
No implementation of the 3.19 equivalent disableRubberBandZoom() | ArcGIS API for JavaScript 3.19
