Auto close widget when another widget is opened (JS 4.x)
2268
12-21-2022 09:25 AM
moremeowbell
I am looking for a way to add some script to my current application that will make widgets close when another widget is opened. The issue I am trying to avoid is having multiple widgets overlapping each other like this:
I found this post that has a solution, but it's using the JS 3.x library.
https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/automatically-close-a-widget-when...
UPDATE:
I have created this code. With only one reactiveUtils it works, but when I add in all of the reactiveUtils it does work. Any suggestions?
    // configure auto close for widgets
    function closeWidget(esriWidget){
      esriWidget.expanded = false
    reactiveUtils.when(
      () => measureExpand.expanded,
        closeWidget(eyeExpand)
        closeWidget(legendExpand)
        closeWidget(btnExpand)
    reactiveUtils.when(
      () => eyeExpand.expanded,
        closeWidget(measureExpand)
    reactiveUtils.when(
      () => btnExpand.expanded,
    reactiveUtils.when(
      () => legendExpand.expanded,
Thanks in advance!
Jennifer Pramuk MGIS, GISP
ReneRubalcava
Esri Frequent Contributor
ReneRubalcava
The Expand widget has a group property that will handle this for you.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Expand.html#group
