Attribution Dijit - change default behaviour ?
1140
04-01-2013 06:16 AM
BillHoney
Does anyone know of a way of making the attribution dijit "open" by default.
When you click on the widget it opens up.  I'd like the map to start up with the dijit already open.
I've tried forcing it open like like below,  but nothing seems to work
var attribution = map.attribution;
// try & force the digit open - none of these work
attribution.declaredClass = "esriAttribution esriAttributionOpen";
attribution.domNode.className = "esriAttribution esriAttributionOpen";
attribution.domNode.click();
Any ideas ?  Bill
BillHoney
Can anyone help with this?
Our customer is insisting that all copyrights appear when the map starts up
Bill
BillHoney
In case anyone has a similar problem, I've found a workaround
map.attribution.domNode.className = "esriAttribution esriAttributionOpen";
But it appears that you can't call this in the map.OnLoad()
I've put it in map.onLayersAddResults() & it works
Bill
