Attributes filling
1855
02-14-2017 02:37 AM
bharathreddy
how to give customized values in attributes while editing
  var newGraphic = new Graphic(point2, null, newAttributes);
FC_Basson
You can create your own attributes object and set the attributes at any time:
var attrobj = {
  x: null,
  y: null,
  comment: ""
newGraphic.attributes = attrobj;
newGraphic.attributes.id = myIDval;
newGraphic.attributes.x = myXval;
newGraphic.attributes.y = myYval;
newGraphic.attributes.comment = myComment;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
FC_Basson
var attrobj = {
  x: null,
  y: null,
  comment: ""
bharathreddy
will that reflect into database
FC_Basson
No, just the graphic's attributes.  You'll still need to push the values through to the editable feature class.
bharathreddy
thank u fc basson it worked
