attribute edit
7054
14
08-31-2015 03:08 AM
SatyanarayanaNarmala
Hi all,
I am trying to implement attribute edit using attribute inspector, the service is displaying but pop up info not getting displayed.
If the problem is with the proxy setting, can anybody help with it. i am using IIS server.
here is the code
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Editable FeatureLayer in Selection Only Mode with Attribute Inspector</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body {
        height: 100%; width: 100%;
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content {position: relative;}
      .esriAttributeInspector {height:100px;}
      .esriAttributeInspector .atiLayerName {display:none;}
      .esriAttributeInspector .atiButton{
        margin-top:1px;
        margin-right:45px;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var map;
      var updateFeature;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/dijit/AttributeInspector",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/config",
        "esri/tasks/query",
        "dojo/query",
        "dojo/parser",
        "dojo/dom-construct",
        "dijit/form/Button",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, AttributeInspector,
        SimpleLineSymbol, SimpleFillSymbol, Color,
        ArcGISDynamicMapServiceLayer, esriConfig,
        Query,dojoQuery,
        parser, domConstruct, Button
        parser.parse();
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
   // esriConfig.defaults.io.proxyUrl = "/proxy/";
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [78.20, 19.00],
          zoom: 11
        map.on("layers-add-result", initSelectToolbar);
        var petroFieldsMSL = new ArcGISDynamicMapServiceLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/IRR/srsp_canal_WRK1/MapServer");
        petroFieldsMSL.setDisableClientCaching(true);
        map.addLayer(petroFieldsMSL);
        var petroFieldsFL = new FeatureLayer("http://gisserver.cgg.gov.in/arcgis/rest/services/IRR/srsp_canal_WRK1/FeatureServer/1", {
          mode: FeatureLayer.MODE_SELECTION,
          outFields: ["objectid","code", "codename", "length", "description", "status_work", "la_status", "ip_status"]
        var selectionSymbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
            new SimpleLineSymbol(
                "solid",
                new Color("yellow"),
            null
        petroFieldsFL.setSelectionSymbol(selectionSymbol);
        petroFieldsFL.on("edits-complete", function() {
          petroFieldsMSL.refresh();
        map.addLayers([petroFieldsFL]);
        function initSelectToolbar(evt) {
          var petroFieldsFL = evt.layers[1].layer;
          var selectQuery = new Query();
          map.on("click", function(evt) {
            selectQuery.geometry = evt.mapPoint;
            petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
              if (features.length > 0) {
                //store the current feature
                updateFeature = features[0];
                map.infoWindow.setTitle(features[0].getLayer().name);
                map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
              else {
                map.infoWindow.hide();
          map.infoWindow.on("hide", function() {
            petroFieldsFL.clearSelection();
          var layerInfos = [
              'featureLayer': petroFieldsFL,
              'showAttachments': false,
              'isEditable': true,
              'fieldInfos': [
                {'fieldName': 'objectid', 'isEditable': false, 'objectid': 'objectid:'},
                {'fieldName': 'code', 'isEditable': false, 'CANAL CODE': 'Acreage:'},
                {'fieldName': 'codename', 'isEditable': false, 'label': 'CANAL NAME:'},
                {'fieldName': 'length', 'isEditable': false, 'label': 'LENGTH IN METERS:'},
                {'fieldName': 'description', 'isEditable': false, 'label': 'CANAL DESCRIPTION:'},
                {'fieldName': 'status_work', 'isEditable': true, 'tooltip': 'WORK PROGRESS', 'label': 'WORK PROGRESS STATUS:'},
                {'fieldName': 'la_status', 'isEditable': true, 'tooltip': 'LAND AQUISITION', 'label': 'LAND AQUISITION STATUS:'},
                {'fieldName': 'ip_status', 'isEditable': true, 'tooltip': 'IP CREATED', 'label': 'IP CREATED STATUS:'}
          var attInspector = new AttributeInspector({
            layerInfos: layerInfos
          }, domConstruct.create("div"));
          //add a save button next to the delete button
          var saveButton = new Button({ label: "Save", "class": "saveButton"},domConstruct.create("div"));
          domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
          saveButton.on("click", function() {
            updateFeature.getLayer().applyEdits(null, [updateFeature], null);
          attInspector.on("attribute-change", function(evt) {
            //store the updates to apply when the save button is clicked
            updateFeature.attributes[evt.fieldName] = evt.fieldValue;
          attInspector.on("next", function(evt) {
            updateFeature = evt.feature;
            console.log("Next " + updateFeature.attributes.objectid);
          attInspector.on("delete", function(evt) {
            evt.feature.getLayer().applyEdits(null, null, [evt.feature]);
          map.infoWindow.setContent(attInspector.domNode);
          map.infoWindow.resize(350, 240);
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;">
      <div id="detailPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
        Click a field to display the attribute inspector with customized fields.
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" id="mapDiv"></div>
    </div>
  </body>
</html>
bharathreddy
Object id in that layer.Below is the code.please help
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body {
        margin: 0;
        padding: 0;
        overflow: hidden;
      #mapDiv{
        margin: 0;
        padding:0;
      #detailPane{
        height:20px;
        color:#570026;
        font-size:12pt;
        font-weight:600;
        overflow:hidden;
        margin-top:1px;
        margin-right:45px;
    </style>
    <script>
        var map;
        var updateFeature;
        require([
        "esri/map",
        "esri/Color",
        "esri/config",
        "esri/tasks/query",
        "dojo/query",
        "dojo/parser",
        "esri/graphic",
        "esri/geometry/Circle",
      ], function (
        Query, dojoQuery,
        parser, domConstruct, Button, Graphic, Circle
          parser.parse();
//              basemap: "streets",
//              center: [78.20, 19.00],
//              zoom: 11
          var petroFieldsMSL = new ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services/editing/MapServer");
          var petroFieldsFL = new FeatureLayer("http://localhost:6080/arcgis/rest/services/editing/FeatureServer/1", {
              outFields: ["CJ_FDR_ID", "CJ_DONE_BY", "CJ_CIR_CODE", "CJ_UID", "CJ_CIR_CODE", "CJ_TOWN_ID", "CJ_LINE_CODE", "CJ_PUID"]
                "solid",
            null
          var circleSymb = new SimpleFillSymbol(
            SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
            new Color([105, 105, 105]),
          ), new Color([255, 255, 0, 0.25])
          var circle;
          petroFieldsFL.on("edits-complete", function () {
              //var petroFieldsFL = evt.layers[1].layer;
              map.on("click", function (evt) {
                  circle = new Circle({
                      center: evt.mapPoint,
                      geodesic: true,
                      radius: 0.2,
                      radiusUnit: "esriMiles"
                  map.graphics.clear();
                  var graphic = new Graphic(circle, circleSymb);
                  map.graphics.add(graphic);
                  selectQuery.geometry = circle.getExtent(); ;
                  //selectQuery.geometry = evt.mapPoint;
                  petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (features) {
                      else {
              map.infoWindow.on("hide", function () {
              var layerInfos = [
                'isEditable': true,
                'fieldInfos': [
                { 'fieldName': 'CJ_FDR_ID', 'isEditable': false },
                { 'fieldName': 'CJ_DONE_BY', 'isEditable': false },
                { 'fieldName': 'CJ_CIR_CODE', 'isEditable': false },
                { 'fieldName': 'CJ_UID', 'isEditable': false },
                { 'fieldName': 'CJ_TOWN_ID ', 'isEditable': true },
                { 'fieldName': 'CJ_LINE_CODE', 'isEditable': true },
                { 'fieldName': 'CJ_PUID', 'isEditable': true }
              var saveButton = new Button({ label: "Save", "class": "saveButton" }, domConstruct.create("div"));
              saveButton.on("click", function () {
              attInspector.on("attribute-change", function (evt) {
              attInspector.on("next", function (evt) {
              attInspector.on("delete", function (evt) {
    </script>
  </head>
      </div>
    </div>
  </body>
</html>
HerdisGudbrandsdottir
Hi, I would like to see the fields in your featurelayer, so go to this address in your browser:
http://localhost:6080/arcgis/rest/services/editing/FeatureServer/1?f=json
And copy/paste the json in here.
bharathreddy
Goodaftn,
I couldnt open above url but I can show the fields.Below are the fields
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field:
Fields:
  • OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID , editable: false , nullable: false )
  • CJ_ACODE ( type: esriFieldTypeString , alias: CJ_ACODE , editable: true , nullable: true , length: 20 )
  • CJ_EXT_CODE ( type: esriFieldTypeString , alias: EXTISTING JOINT CODE , editable: true , nullable: true , length: 50 )
  • CJ_CLASSIFICATION ( type: esriFieldTypeString , alias: CLASSIFICATION , editable: true , nullable: true , length: 20 , Coded Values: [Straight: Straight] , [D/T: D/T] )
  • CJ_FDR_NAME ( type: esriFieldTypeString , alias: FEEDER NAME , editable: true , nullable: true , length: 20 )
  • CJ_GUARANTEE ( type: esriFieldTypeDate , alias: GUARANTEE PERIOD , editable: true , nullable: true , length: 36 )
  • CJ_DEPTH ( type: esriFieldTypeString , alias: DEPTH OF CABLE JOINT , editable: true , nullable: true , length: 30 )
  • CJ_VOLT_KV ( type: esriFieldTypeDouble , alias: VOLTAGE IN KV , editable: true , nullable: true , Coded Values: [400: 400] , [230: 230] , [110: 110] , ...6 more... )
  • CJ_SS_ID ( type: esriFieldTypeString , alias: SS CODE , editable: true , nullable: true , length: 30 )
  • CJ_SDIV_NAME ( type: esriFieldTypeString , alias: CJ_SDIV_NAME , editable: true , nullable: true , length: 30 )
  • CJ_MAKE ( type: esriFieldTypeString , alias: MAKE , editable: true , nullable: true , length: 20 , Coded Values: [Raychem: Raychem] , [Vachem: Vachem] , [Hari: Hari] , ...7 more... )
  • CJ_TYPE ( type: esriFieldTypeString , alias: TYPE , editable: true , nullable: true , length: 20 , Coded Values: [Tapex: Tapex] , [HS: HS] , [M Seal: M Seal] , ...4 more... )
  • CJ_FROM_LINE_ID ( type: esriFieldTypeString , alias: FROM LINE CODE , editable: true , nullable: true , length: 30 )
  • CJ_DT_ID ( type: esriFieldTypeString , alias: DT INTERNAL ID , editable: true , nullable: true , length: 30 )
  • CJ_STATUS ( type: esriFieldTypeString , alias: STATUS , editable: true , nullable: true , length: 20 , Coded Values: [In Service: In Service] , [Out of Service: Out of Service] )
  • ENABLED ( type: esriFieldTypeSmallInteger , alias: Enabled , editable: true , nullable: true , Coded Values: [0: False] , [1: True] )
  • CJ_FM_FDR_ID ( type: esriFieldTypeString , alias: CJ_FM_FDR_ID , editable: true , nullable: true , length: 50 )
  • CJ_FM_FDR_ID2 ( type: esriFieldTypeString , alias: CJ_FM_FDR_ID2 , editable: true , nullable: true , length: 50 )
  • CJ_FM_FDR_INFO ( type: esriFieldTypeInteger , alias: CJ_FM_FDR_INFO , editable: true , nullable: true )
  • CJ_FM_ET_WEIGHT ( type: esriFieldTypeInteger , alias: CJ_FM_ET_WEIGHT , editable: true , nullable: true )
  • CJ_DONE_ON ( type: esriFieldTypeString , alias: JOINT DONE ON , editable: true , nullable: true , length: 30 )
  • CJ_SS_SEC_NAME ( type: esriFieldTypeString , alias: CJ_SS_SEC_NAME , editable: true , nullable: true , length: 30 )
  • CJ_PUID ( type: esriFieldTypeString , alias: CJ_PUID , editable: true , nullable: true , length: 30 )
  • CJ_VIRTUAL_REAL ( type: esriFieldTypeString , alias: VIRTUAL/REAL , editable: true , nullable: true , length: 10 , Coded Values: [Real: Real] , [Virtual: Virtual] )
  • CJ_TO_LINE_ID ( type: esriFieldTypeString , alias: TO LINE CODE , editable: true , nullable: true , length: 30 )
  • CJ_LINE_CODE ( type: esriFieldTypeString , alias: CJ_LINE_CODE , editable: true , nullable: true , length: 30 )
  • CJ_TOWN_ID ( type: esriFieldTypeString , alias: TOWN CODE , editable: true , nullable: true , length: 3 )
  • CJ_ORG_ID ( type: esriFieldTypeString , alias: CJ_ORG_ID , editable: true , nullable: true , length: 20 )
  • CJ_UID ( type: esriFieldTypeString , alias: CJ_UID , editable: true , nullable: true , length: 30 )
  • CJ_ID ( type: esriFieldTypeString , alias: INTERNAL ID , editable: true , nullable: true , length: 30 )
  • CJ_REMARKS ( type: esriFieldTypeString , alias: REMARKS , editable: true , nullable: true , length: 255 )
  • CJ_FM_OP_VOLTAGE ( type: esriFieldTypeInteger , alias: CJ_FM_OP_VOLTAGE , editable: true , nullable: true )
  • CJ_FM_PHASE_DESG ( type: esriFieldTypeInteger , alias: CJ_FM_PHASE_DESG , editable: true , nullable: true )
  • CJ_FM_PARENT_SRC_ID ( type: esriFieldTypeDouble , alias: CJ_FM_PARENT_SRC_ID , editable: true , nullable: true )
  • CJ_REGION_ID ( type: esriFieldTypeString , alias: REGION_ID , editable: true , nullable: true , length: 30 )
  • CJ_CIR_CODE ( type: esriFieldTypeString , alias: CJ_CIR_CODE , editable: true , nullable: true , length: 10 )
  • CJ_SS_SEC_ID ( type: esriFieldTypeInteger , alias: SS SECTION ID , editable: true , nullable: true )
  • CJ_CATEGORY ( type: esriFieldTypeString , alias: CJ_CATEGORY , editable: true , nullable: true , length: 30 )
  • CJ_AIN ( type: esriFieldTypeString , alias: CJ_AIN , editable: true , nullable: true , length: 30 )
  • CJ_DONE_BY ( type: esriFieldTypeString , alias: CJ_DONE_BY , editable: true , nullable: true , length: 30 )
  • CJ_CIRCUIT_NO ( type: esriFieldTypeInteger , alias: CJ_CIRCUIT_NO , editable: true , nullable: true )
  • CJ_FDR_ID ( type: esriFieldTypeString , alias: FEEDER CODE , editable: true , nullable: true , length: 30 )
  • CJ_DISTANCE_M ( type: esriFieldTypeString , alias: CJ_DISTANCE_M , editable: true , nullable: true , length: 1073741822 )
One thing I can say is that fields are case-sensitive, so try replacing 'objectid' with 'OBJECTID' in your code, or even better use petroFieldsFL.objectIdField to reference the field. E.g.: updateFeature.attributes[petroFieldsFL.objectIdField]
But it will not do the trick, since it is only called directly in your code in a console.log statement.
A test: Do you get an error if you specify OBJECTID as outfield?
outFields: ["OBJECTID","CJ_FDR_ID", "CJ_DONE_BY", "CJ_CIR_CODE", "CJ_UID", "CJ_CIR_CODE", "CJ_TOWN_ID", "CJ_LINE_CODE", "CJ_PUID"]
bharathreddy
GoodMorning,
THank u very much herids
