Attr.specified is deprecated error
1723
6
04-22-2014 12:57 PM
DanielCooke
Hi all,
I am currently working on a JavaScript API that shows 4 categories using check-boxes. However when I refresh the page and inspect the element I get the following error:
Attr.specified is deprecated. Its value is always true. init.js:148
Resource interpreted as Script but transferred with MIME type text/plain: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json&callback=dojo.i...". init.js:1046
n._attach init.js:1046
n init.js:1045
c.get init.js:1414
s init.js:786
e init.js:790
A init.js:796
d._load init.js:702
(anonymous function) init.js:173
l.constructor init.js:641
(anonymous function) init.js:104
(anonymous function) init.js:390
g.forEach init.js:223
p.setBasemap init.js:389
p.constructor init.js:1529
(anonymous function) index.html:39
ga init.js:32
(anonymous function) init.js:32
ha init.js:32
ea init.js:32
s init.js:34
Thank you for your help!
Dan
P.S.
I've included a attachment of the code I have in a .txt
RobertoPepato
Hi Daniel,
Are you serving your page though a web server (http)? Or are you just double-clicking your html file and running locally (without a web server)?
DanielCooke
Hi Daniel,
We are running on a local server, however I can view it on a webpage through the index.html I create and save on the C drive.
MichaelVolz
Esteemed Contributor
Daniel:
Why do you add http://ho213-radell19:6080/arcgis/rest/services/dtcook13/Final/MapServer as a dynamicMapServiceLayer and then give it imageParameters before adding it to the map?
DanielCooke
Daniel:
that just answered my question...thanks!
MichaelVolz
Can you explain how that answered your question?
DanielCooke
looking back at my code (and code that i had continued on) it made me realize that I had called dynamicMapServiceLayer twice...thus, not allowing it to work as i want it to.
