Attachments within a popuptemplate
4469
11
01-17-2017 01:14 PM
EvonFranklin
Attachments set from Arcgis Desktop Service seem to not be displaying in API 4.2, I am using the code below
popupTemplate: {
                                    title: "{CONST}",
                                    content: [{
                                                type: "attachments"
                                                  type: "text",
                                                  text: "Sample data"
Can anyone confirm if this is working to date or not as yet? Thanks for any tips and advice.
KellyHutchins
Esri Notable Contributor
I just ran a quick test using a hosted feature service and attachments and was able to view them in a 4.2 popup. Here's my test code:
<!DOCTYPE html>
<html dir="ltr">
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"
  <meta name="description" content="[Multiple popup elements - 4.2]">
  ArcGIS API for JavaScript, https://js.arcgis.com
  For more information about the popup-multipleelements sample, read the original sample description at developers.arcgis.com.
  https://developers.arcgis.com/javascript/latest/popup-multipleelements/index.html
  <title>Multiple popup elements - 4.2</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.2/dijit/themes/claro/claro.css">
  <script src="https://js.arcgis.com/4.2/"></script>
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "dojo/domReady!"
    ], function(Map, MapView, FeatureLayer) {
      // setup the map
      var map = new Map({
        basemap: "hybrid"
      var view = new MapView({
        container: "mapDiv",
        map: map,
        center: [-118.399400711028, 34.08713590709093],
        zoom: 8,
        // Since there are many elements, it is best to dock the popup so
        // the elements display better rather than have to scroll through them all.
        popup: {
          dockEnabled: true,
          dockOptions: {
            buttonEnabled: false,
            breakpoint: false
      var featureLayer = new FeatureLayer({
        url: "http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/grafitti/FeatureServer/0",
        popupTemplate: {
          title: "Graffitik",
          // Set content elements in the order to display.
          // The first element displayed here is the fieldInfos.
          content: [{
            // It is also possible to set the fieldInfos outside of the content
            // directly in the popupTemplate. If no fieldInfos is specifically set
            // in the content, it defaults to whatever may be set within the popupTemplate.
            type: "fields",
            fieldInfos: [{
              fieldName: "description",
              visible: false,
              label: "Details"
            type: "attachments"
        outFields: ["*"]
      map.add(featureLayer);
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
EvonFranklin
I will look at this now and give it a shot. Also on the Arcgis Desktop program when compiling your service is there any special setting you selected in order to add the attachment? I just added the attachment via attribute table.
KellyHutchins
I tested with an ArcGIS Online hosted service.  You'll want to check your service to make sure Has Attachments is set to true.
EvonFranklin
On my service layer there is this attritbute.
"Has Attachments: true" set
KellyHutchins
Then you should be good to go.
EvonFranklin
Anyway to get it to auto display instead of providing a clickable link?
KellyHutchins
Not without writing code to get the attachments and add then add them to the media section of the popup.
EvonFranklin
If I could pull the URL for the attachment I could then figure out the rest myself.
HeathAnderson
Were you able to figured this out?
I am trying to do the same thing.  I know the url path to query for the attachment of a specific feature and get a json response, but i don't know how to hold the attachment ObjectID in a variable so that I can populate the mediaInfos section.
