Attachments in Popup Template
1957
02-14-2020 03:06 AM
MatthieuThery1
I am trying to show attachments in a popup (mapimagelayer) using that piece of code, and it's not working (I can see the attachment in the rest end point (pdf)):
popupTemplate: {
  outFields: ['*'],
  title:"test",
  content: [{type: "attachments"}]
LeoLiu1
Hi Matthieu,
Are you using 4.x API? Here is the example:
AttachmentsContent | ArcGIS API for JavaScript 4.14
// Create the AttachmentsContent popup element
// If the selected feature has attributes associated with it, they will display within the popup
let attachmentsElement = new AttachmentsContent({ displayType: "list" });
// Create the PopupTemplate
let template = new PopupTemplate({
   title: "Beverly Hills trees by block",
   outFields: ["*"],
   content: [attachmentsElement]
If you are using 3.x API, it should like this:
Popup with related fields | ArcGIS API for JavaScript 3.31
var popupTemplate = new PopupTemplate({
    "title": "Beverly Hills Trees By Block",
    "fieldInfos": [
    "description": "",
    "showAttachments": true,
    "mediaInfos": []
var featureLayer = new FeatureLayer([LAYERURL], {
    mode: FeatureLayer.MODE_SNAPSHOT,
    infoTemplate: popupTemplate,
    outFields: ["*"]
