arcpy script to convert shapefile to Json format
1951
01-20-2013 05:10 AM
AmmarAssem1
i need arcpy script to use it when creating Geoprocessing task.
AnthonyGiles
Honored Contributor
Ammar,
There is a script on ths page that takes the json produced in flex and converts it to shapefiles, I have used it and it works. Maybe of some use:
http://forums.arcgis.com/threads/33618-FAO-Robert-Scheitlin-or-anyone-who-knows-about-saved-graphics...
Also there is a script here to convert feature class to JSON:
http://arcscripts.esri.com/details.asp?dbid=15545
Regards
Anthony
AmmarAssem1
Hi Anthon,
Thanks for reply, I downloaded (convert feature class to JSON Script) and try to run it but this error occurred
<type 'exceptions.AttributeError'>: 'module' object has no attribute 'write'
Failed to execute (FeatureClassToGeoJSON).
I follow steps in ReadMe textfile but noway.
I gooogle this error but I cannot find any solution
Best wishes
nicogis
you can also use Generate operation serializing shapefile to json (esri)
see http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/portal_addshapefile
AmmarAssem1
Hi Ciava,
I know this way but the problem the user upload cadfile, then display cad file into map but the are are two problems
1- this example only for shape file and user need to upload cad not shape file and this shape file shoud be in define format
zip file.
2-Cad file that user upload it may be not have coordinate system so I create geoprocessing task to set coordinate to cad file and i wish to convert cad file to json to display it into map.
Thanks and best wished.
