ArcIMS Queryzoom replacement?
1132
02-16-2011 10:49 AM
HannahMelton
We are in the process of migrating our Javascript/HTML arcIMS veiwer to ArcGIS Server Javascript API.  We currently have separate database searches not located in the frame of the mapping website.  We use the following command line to zoom to a parcel or address.  HOw can we recreate this functionality in ArcGIS Server?  Thanks!
http://pslgis.cityofpsl.com/website/cityofpsl/viewer.htm?QUERYZOOM=YES&QUERY=parce_id=""
JeffPace
Are you using the Javascript sample viewer? or a custom application.  Unfortunately, queryzoom is not a built in functionality.  However it is reasonably easy with the API.
If you could tell us a bit more about your Server application we could provide a better answer.
