ArcGISDynamicMapServiceLayer - Shaging Polygons in JavaScript Based on Ranges
993
09-04-2011 07:31 PM
MattBrunsdon
Hey Guys,
I'm new to the API, I have successfully added a ArcGISDynamicMapServiceLayer of postcode boundaries to my map.
I was wondering if there is a way of changing the color of these polygons in the JavaScript based on a range of data that is stored in the service? For example: all polygons with a feature attribute "income" and a  value of "1" are shaded red.
I know this is probably possible at the service level, however I would prefer not to have to create a new service for each range of values that I need to shade the polygons for.
Is that possible at all?
Thanks for your help!
StephenLead
Honored Contributor
Matt,
As far as I know, you can't do this with a Dynamic layer.
Instead, you could add your polygons as a Feature layer.
A feature layer can have a renderer, which would allow you to specify your desired class breaks.
Steve
