ArcGISDynamicMapServiceLayer refresh manually does not work
7415
11
05-11-2015 11:02 PM
takashiiwata
i am making ArcGISDynamicMapServiceLayer to show sth and i want to refresh the data manually.
i mean i don't want to refresh automatically when the map resizing or moving.
i tried layer option like below but they don't work.
     useMapTime: false
     refreshInterval: 0
if anyone have idea, plz help.
Tags (1)
RobertScheitlin__GISP
Takashi,
   A FeatureLayer downloads the actual geometry from the server and depending on the mode (i.e. shotshot) it downloads all the data initially. The ArcGISDynamicMapServiceLayer just requests a new image from the server every time something changes like the extent or visible layers, etc. What you are wanting is not possible using ArcGISDynamicMapServiceLayer.
Takashi,
   The ArcGISDynamicMapServiceLayer in the JS API will always refresh (request  an new image from the server) when ever you pan or zoom the map there is no property you can set to change this default behavior.
takashiiwata
Robert,
Thanks very much for your answer.
I got it but I still want to show ArcGISDynamicMapServiceLayer in a state when the Layer was visible.
It is like select all in FeatureLayer.selectFeature.
if you have idea, let me know please.
Takashi,
   Sorry I don't understand what you are wanting to do.
A ArcGISDynamicMapServiceLayer will show all visible layers unless you set a definition Expression for one or more of the layers or set the visibleLayers.
takashiiwata
Robert,
I'm sorry I needed more explanation
I want to say the shown data by using "FeatureLayer.selectFeature" will never update even delete data from table.
is that right?
I want to do like that on ArcGISDynamicMapServiceLayer without any selection.
Takashi,
takashiiwata
Robert,
Thank you so much.
I need to think again the way to show the data to FeatureLayer with LabelLayer.
Takashi,
   Can you explain more about why you don't want the layer to refresh?
takashiiwata
Robert,
it is because I have a search button for searching featurelayer data and showing the dynamicmapservicelayer.
why i chose dynamicmapservicelayer is for performance and lavel.
Takashi,
   OK then it sounds like you want to set the dynamicmapservicelayers
LayerDefinitions property using the same sql that you used to search then.
