ArcGISDynamicMapServiceLayer LayerDefinitions 10.0 to 10.2
1282
03-20-2014 11:09 AM
JamieSimko
We are currently upgrading from a 10.0 to a 10.2 server and are having issues with one of our apps built in JavaScript. The JavaScript API is generating an export map call with layer definitions setup like:
6:(USERNAME = 'test');7:(USERNAME = 'test')
Which works fine in 10.0 but fails in 10.2. I looked at examples in the documents and found one here which shows that the request should be sent with the parameter like:
{6:(USERNAME = 'test'),7:(USERNAME = 'test')}
Note that it is wrapped in curly braces and layers are separated by commas instead of semi-colons.
To setup these definitions in the code all I did was (not the exact code):
var definitions = []; definitions[6] = '(USERNAME = 'test')'; definitions[7] = '(USERNAME = 'test')';  service.setLayerDefinitions(definitions);
Anybody have any thoughts on what I might be doing wrong or if this could be a bug in the api?
NOTE: 10.0 api works with commas instead of semi-colons but fails when wrapped with curly braces. 10.2 only works with semi-colons and must be wrapped with curly braces
- Jamie
JamieSimko
My original question here had the actual bug omitted from it.
The root cause of my error was that I used "!=" instead of "<>" for not equals in my layerDefs.
Here are my test cases for those interested; there are a couple differences between 10.0 and 10.2
- I removed the samples from each test but kept pass/fail & the key parts that differentiated.
- TEST 1 & 2 are in the format sent by the REST API
- I was using test 2 in my code which caused the issue for me (needed to switch to test 1 format)
- I don't think I've included all cases, there are probably at least 2 tests I missed here that weren't relevant.
**************************                 10.0 TESTING ************************** TEST 1 - PASS (JavaScript API will send like this (using <> as operator))  TEST 2 - PASS (JavaScript API will send like this (using != as operator))  TEST 3 - FAIL ( wrapped in curly braces, separated by semi-colons, and not equals operator: "<>" )  TEST 4 - FAIL ( wrapped in curly braces, separated by semi-colons, and not equals operator: "!=" )  TEST 5 - FAIL ( wrapped in curly braces, separated by semi-colons, and not equals operator: "!=" )  TEST 6 - FAIL ( wrapped in curly braces, separated by commas, and not equals operator: "!=" )  **************************                 10.2 TESTING ************************** TEST 1 - PASS (JavaScript API will send like this (using <> as operator))  TEST 2 - FAIL (JavaScript API will send like this (using != as operator))  TEST 3 - FAIL ( wrapped in curly braces, separated by semi-colons, and not equals operator: "<>" )  TEST 4 - FAIL ( wrapped in curly braces, separated by semi-colons, and not equals operator: "!=" )  TEST 5 - FAIL ( wrapped in curly braces, separated by semi-colons, and not equals operator: "!=" )  TEST 6 - PASS ( wrapped in curly braces, separated by commas, and not equals operator: "!=" )
JamieSimko
JeffPace
I think you ran into ESRI's new "standardized" SQL
you can turn this off
http://support.esri.com/en/knowledgebase/techarticles/detail/41561
