arcgis works on IE but not Chrome/Firefox
9736
29
09-03-2014 02:11 PM
NathanLindley
Map just keeps trying to load in Chrome/Firefox but works great in Internet Explorer...any ideas??
Using:
<script type="text/javascript" src="http://js.arcgis.com/3.10/"></script>
Thanks in advance for any suggestions!
NathanLindley
No, it is a subscription based service.  I wish it was public, as it would be a lot easier to show you guys what exactly is going on.  Is there any other information you need?
Previously we used http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5 and had no issues with either IE/FireFox.  Upgraded to add scalebar and ran into this issue.
ScottRutzmoser2
I was looking at your JSFiddle example...I couldn't get it work because you are using some aspx parameters but I did notice a couple of potential issues.
I think this:
dojo.require("esri/layers/ArcGISDynamicMapServiceLayer");
should be:
dojo.require("esri.layers.ArcGISDynamicMapServiceLayer");
and you may need to add this:
dojo.require("esri.symbol.Symbol);
NathanLindley
When I include: dojo.require("esri.symbol.Symbol); this error comes up:
I have tried pretty much every combination of dojo.require that I can and it still gets that javascript error on FF/chrome.
Also, thanks a lot for your help.  I really appreciate it.
RobertScheitlin__GISP
Scott,
  Wouldn't that be
dojo.require("esri.symbols.Symbol");
ScottRutzmoser2
you are correct sir, esri.symbols.Symbol
NathanLindley
Yep, tried that as well.  Same result.
Nathan,
  OK checking every spelling and use of symbols now (everywhere in your code that you have esri.symbol... it has to be esri.symbols intead:
var markerSymbol = new esri.symbols.SimpleMarkerSymbol(esri.symbols.SimpleMarkerSymbol.STYLE_SQUARE, 28, new esri.symbols.SimpleLineSymbol(esri.symbols.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([27, 236, 86]), 0.75), new dojo.Color([255, 0, 0, 0.30]));
NathanLindley
Edit fiddle - JSFiddle
Changed and same error:
Nathan,
   Try this fiddle. I think I have all the issues worked out
NathanLindley
Thank you soooo much Robert, it works like a charm!
Very confusing that the require has a different path than the actual variable declarations.
Thanks again!
