ArcGIS Service Path
910
09-16-2010 06:18 AM
RachelLi
Hello,
I am using ArcGIS Server and ArcSDE 10, workgroup.
I updated one ArcSDE layer in ArcMap, i.e I changed the layer query from (NOID=???S???) to (NOID=???S??? or NOID=???V???). But under the service path, the layer definition was still (NOID=???S???). When I referred to the map by using service path URL, the layer did not update.
I deleted the service yesterday, but I can still see the path under rest.
Today I recreated the service and can refer to the map using the same URL I had before, but I cannot see the path under rest folder.
There must be some steps I missed to update the server path. Could you please help me? I have tried to restart the service and ArcSDE service, cannot fix the problem.
Hopefully I have expressed myself clearly,
Rachel
derekswingley1
RachelLi
Thank you very much for the information Derek,
Rachel
Sounds like you need to clear your REST cache:
http://help.arcgis.com/EN/arcgisserver/10.0/apis/rest/clearcache.html
http://services.arcgisonline.com/ArcGIS/SDK/REST/admin.html
