Arcgis server's map service in Web appbuilder?
4034
01-21-2016 11:45 PM
shankarb
We are using ArcGIS for Server 10.3.1 for publishing our map services.  We are new to web app builder so have one architectural query. Can we use/access Arcgis server's published map service into web app builder as "web map"? If yes please let me know how to access?
Thanks in advance.
Kind Regards
Shankar
JakeSkinner
Esri Esteemed Contributor
Hi Shankar,
Yes, you can add the ArcGIS Server service to a web map and then use the web map in Web AppBuilder.  If you are looking for a way to access the layer using JavaScript, see the very bottom section in the below link:
Working with web maps | Guide | ArcGIS API for JavaScript
shankarb
Thanks for reply Jake
RebeccaStrauch__GISP
If instead of accessing thru a web map, if you want to access them directly in web AppBuilder developer edition, look at LocalLayerWidget and AccessifizrWidget​
find this and other custom widgets and information for the dev edition Web AppBuilder Developer Edition - Customization Resource List
and for help installing Tips and Observations for getting Web AppBuilder -  Developer Edition Installed
