ArcGIS Portal REST: Which token dispenser to use to access secure map services?
14394
10
01-26-2016 09:29 AM
DirkVandervoort
We are writing a REST application to access AGS map services. We cannot use the ArcGIS JSAPI - everything I do can only use REST verbs (GET, PUT, etc.)
  • We want to access secure map services that are hosted on-premise on ArcGIS Server
  • We have on-premise Portal for ArcGIS Server
  • ArcGIS Server security (User Store, Role Store, Authentication Tier, and Authentication Mode) uses Portal for ArcGIS
To get an Oauth2.0 token I can use this URL:
https://<DOMAIN>/portal/sharing/rest/oauth2/token?grant_type=client_credentials&client_id=<CLIENT_ID>&client_secret=<CLIENT_SECRET>
Which returns a JSON payload like this:
{"access_token":"fCsz6hbXOsnjfIt1j30HAofVMcu3xEhnsgao2rq4_98xOAlf72oR17LYvj1gydJ7ZYnhzxzU4G-vBWNW_0thHQqSYt-HDuzVenv-v6nws1xkGu6XOI3peobXFobZo5QV6NcglZYF6YiFbMM8MPdE7A..","expires_in":7200}
To get an old-fashioned REST token I can use this URL:
https://<DOMAIN>/portal/sharing/generateToken?f=json&username=<USERNAME>&password=<PASSWORD>&clientip=requestip
{"token" : "KfD9KGedbu2lDrBc2umSVv08XDFCsU8HuKU0yBiFoFk375ahReXmcfVBbsGbGr1iotf003H319dG35T-7Q5-c933dWD0dfLPaflTu4QucS4jJ2Zcz0oIprFspEzk78tHky0IeuHswBudKDbebOQISQ..","expires" : 1453833598866,"ssl" : true}
I want to access:
https://<DOMAIN>arcgis/rest/services/SampleWorldCities/MapServer?f=json
In the pre-Portal for ArcGIS days of REST I could use a URL:
https://<DOMAIN>arcgis/rest/services/SampleWorldCities/MapServer?f=json&token=<SOMETOKEN>
where <SOMETOKEN> was obtained from the REST token dispenser.
HOWEVER: neither of the tokens I’ve obtained from the Portal dispenser nor the REST dispenser work. Both return:
{"error":{"code":498,"message":"Invalid Token","details":[]}}
THE QUESTIONS:
  • Which token dispenser do I use?
  • How do I string together a URL that uses a token I have obtain (from the correct source) then I can use to access our secured services?
TIA
BrianJohnston4
I too can only generate a valid token if I use the Primary Admin Account.  If I use any other account, it will generate the token for the ArcGIS Server, but any attempt to use the token returns "Invalid Token".   What is the work around here?  I cannot give the Primary Admin Account to external users and systems.
We are using version 10.9.1.
