Arcgis Online Secure service vs Arcgis server secure service token
2579
02-01-2016 06:40 AM
JimBridge
I am wokring on an app that I'm updating to use Secure Services. If I'm running from a map on my Arcgis server I can retrive a token and generate the map and everything runs fine. If I let he sign in popup come up I login with the userid /password it works fine.  If i run against the map with it published as public it works fine.  If I run against a map on Arcgis Online I can get a token but I my map never returns.  If i run against the map with it published as public it works fine.  I assume the issue is with the token or how i'm creating the map. I've tried adding a referer ip and tried using the RquestIP.
I'm getting the token with the following :
            if (tokenUrl != "")
                var data = new NameValueCollection();
                //data["client_id"] = username;
                //data["client_secret"] = password;
                data["username"] = username;
                data["password"] = password;
                data["expires"] = "2440";
                data["client"]="RequestIP";
                data["f"] = "json";
                JavaScriptSerializer jserialize = new JavaScriptSerializer();
                TokenInfo x = jserialize.Deserialize<TokenInfo>(_getResponse(data, tokenUrl));
                myToken = x.token;
                var epoch = new DateTime(1970, 1, 1, 0, 0, 0, DateTimeKind.Utc);
                var expire = epoch.AddMilliseconds(x.expires).ToLocalTime();
                dictionary.Add("token", myToken);
                dictionary.Add("expire",expire.ToString());
                return dictionary;
            else
                dictionary.Add("token","");
                return dictionary;
        public class TokenInfo
            public string token { get; set; }
            public long expires { get; set; }
            public bool ssl { get; set; }
        private string _getResponse(NameValueCollection data, string url)
            string responseData;
            var webClient = new WebClient();
            var response = webClient.UploadValues(url, data);
            responseData = System.Text.Encoding.UTF8.GetString(response);
I do get a token value back.
I'm creating the map through
configOptions = {
                    webmap: arcgisID,
                    title: "",
                    subtitle: "",
                    sharingurl: "https://tylergis.maps.arcgis.com/sharing/rest/content/items/"
   arcgisUtils.createMap(configOptions, "map").then(function (response) {
I do have it set to go through the proxy page where it should be handling adding the token. When I run this against the sercure services on my local arcgis server it does work .
I did try registering the token before this call but it didn't help.
                var tokenOptions = {
                    expires: 1454341793222,
                    ssl: true,
                    client:"RequestIP",
                    token: "6p-T1f4xsDozwO9mvGgeN_f8h89u2yeK5FsJPEo-1cRS6IWtwV5XjWofswW6_dAkJ1XNRVHF-7bWbNDqL70z_hyzZF4Dx3BxXbM0uELElCFjz5ikOSAjCCZA0Fm7JAUO6sjy7dg7ogLQThsqjEniIQ..",
                    userid: "myuserid"
                EsriId.registerToken(tokenOptions); (response) {
I've been assuming that the  referer information I'm providing is wrong but at this point I'm not sure.
Thanks
Jim
