ArcGIS Online Map using URL does not work with PhoneGap 2.7
1395
05-07-2013 04:12 AM
AlexChen
Hi all,
I wanted to show my public accessible ArcGIS Online map with URL on a simple Hello World PhoneGap project with Eclipse. Eclipse threw out the following error in LogCat.
Web Console:RequestError: Unable to load file: //www.arcgis.com/sharing/rest/content/items/{MapId}?f=json status: 0 at http://serverapi.arcgisonline.com/jsapi/arcgis/3.4compact/:15
Just wondering anyone have had any successful experience with using ArcGIS Online web map with PhoneGap?
Many thanks in advance!
Cheers,
Alex
SathyaPrasad
Use this code in your js app before getting the webmaps:
esri.arcgis.utils.arcgisUrl = esri.arcgis.utils.arcgisUrl.replace("file:", "http:");
AndyGup
Alex,
Thanks to @SathyaPrasad the workaround at this point in time is to force Phonegap/Cordova to use HTTP.
Add the following for web maps:
And, if you are using the locator (geocoder) widget:
widget._arcgisGeocoder.url = widget._arcgisGeocoder.url.replace("file:", "http:")
Here's a psuedo-code example using the new AMD pattern:
       require(["esri/map","esri/arcgis/utils","esri/dijit/Legend","esri/dijit/Scalebar"],
                function(Map,utils,Legend,Scalebar) {
                    var map = null;
                    utils.arcgisUrl = utils.arcgisUrl.replace("file:", "http:");
                    var mapDeferred = utils.createMap("4778fee6371d4e83a22786029f30c7e1", "mapDiv");
                    mapDeferred.then(function(response) {
                        dojo.byId("title").innerHTML = response.itemInfo.item.title;
                        dojo.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
                        map = response.map;
