ArcGIS Online API Javascript - toggle layer visibility
1623
03-30-2014 10:05 PM
MonaBartling
Hey everyone,
I have a webmap on ArcGIS Online (I dont use ArcGIS Server) and would like to create an application with js. This, I already was able to do. However, I am wondering how it is possible to toggle the layer visibility. I read the tutorial how to toggle layers provided by ArcGIS. Anyway, it uses the expression "ArcGISDynamicMapServiceLayer.setVisibleLayers()". But I cant use this expression when I just uploaded a map to ArcGIS Online and I use this webmap in js right? I dont have a direkt URL to the layers of the webmap. Havent found a solution how to toggle the layer visibility. Would be glad to get some hints.
ManojrajTeli
This might help you
Toggle Layer Visibility
This forum post might help you
Toggle Visibility
Manojraj
MonaBartling
Thanks Manojraj for the reply.
But the example also works with "ArcGISDynamicMapServiceLayer", which means that I need a direct link to the layer I want to toggle. But how is that posible if I have the layers in my webmap and only a link to that map and not to the layer?
