ArcGIS JS query from geometry
1395
06-19-2023 02:09 AM
Wade
I drew a range on the map, and used query to query which objects are in the geometry, but the result was not very accurate.
// evt.vertices draw-complete
let polygon = new Polygon({
                        type: "polygon",
                        rings: evt.vertices,
                        spatialReference: {
                            wkid: 3826
let drawExtent = new Graphic({
                    geometry: polygon,
                    symbol: {
                        type: "polygon-3d",
                        symbolLayers: [{
                            type: "fill",
                            material: {
                                color: [0, 0, 0, 0]
                            outline: {
                                color: "red",
                                width: 1
Promise.all(sceneView.map.allLayers.map(function (view) {
         if (view.type === "scene") {
                            const query = view.createQuery();
                            query.geometry = drawExtent.geometry;
                            query.spatialRelationship = "intersects";
                            query.returnGeometry = true;
                            return view.queryFeatures(query)
                                .then(function (result) {
                                    let queryResultLayer = [];
                                    if (result.features.length > 0) {
                                        result.features.forEach(function (item) {
                                           queryResultLayer.push(item.layer.title);
                                    return queryResultLayer;
                        .then(function (results) {
                            // results
Sage_Wall
Hi @Wade , it looks like you are passing in a graphic as the `query.geometry` instead of a Geometry object (or one of it's subclasses.)
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-Query.html#geometry
Wade
Hi @Sage_Wall
The above is just part of my program, when I query, I pass drawExtent.geometry.
Sage_Wall
What is the geometry you are passing into the query?  Does it have a spatial reference defined? Would it be possible to create a codepen or provide a complete example showing how the expected results differ from the query result?
Wade
The code update, polygons are generated after my drawing is done, Mainly drawing objects in range queries.
Excuse me, the query range is XYmin XYmax, not the range of 3D objects, so it will be inaccurate?
