ArcGIS JS Portal Login
3048
6
02-26-2022 02:27 AM
Wade
When I set the portal, the layer is private in ArcGIS Enterprise, the login screen appears, how to log in it in the application?
require([
    "esri/config"
], function (
    esriConfig
    esriConfig.portalUrl = "https://MyApp/portal/";
GaryB
Hi Wade, this link may help with what you are trying to do: https://developers.arcgis.com/javascript/latest/arcgis-organization-portals/
Wade
Hi GaryB
The document describes the ArcGIS Enterprise part, not very clear, is there a practical example?
GaryB
yes, I recall struggling with this a bit, try this:
let info = new OAuthInfo({appId: 'xxxxxxxxxxxxxxxx', portalUrl: 'https://my.portal.url/portal', popup: false})
esriId.registerOAuthInfos([info])
esriId.checkSignInStatus(info.portalUrl + '/sharing').then(function () {
    let portal = new Portal({url: 'https://my.portal.url/portal'})
    portal.authMode = 'immediate'
    portal.load().then(
        function () {
            console.log(portal.user.username + ' is now connected to the portal')
            // call my afterSuccessfulLogin function
        function (error) {
            console.log("couldn't successfully load the portal")
Wade
ArcGIS Enterprise can also create appId?
The current way is to use ArcGIS Server generate token for verification.
Lerman
Hello GaryB, I tested this method, but the user still needs to log in once. Is there a solution to build the identity information into the program without requiring the user to log in again? Thank you so much!
Wade
Hi @GaryB, I tested this method, but the user still needs to log in once.  Is there any example, using the token method, the user does not need to log in once ?
