ArcGIS JS API 3.x CDN Lifetime
1367
11-26-2025 11:41 PM
Muhammad_AzhaziqBin_Mohd_Azlan
I have returning client that currently run a web application using ArcGIS JS API 3.x and it directly referencing 3.x API using CDN.
Anyone knows how long the 3.x library will be available via CDN?
BlakeTerhune
ArcGIS API for JavaScript, Version 3.x Retirement
ArcGIS API 3.x for JavaScript was retired on July 1, 2024.
After retirement, the 3.x API will remain hosted on our CDN for a multi-year grace period
Your guess on how long a "multi-year grace period" actually is. I would say two years is probably the shortest time. For safety, you should probably plan to migrate from 3.x in 2026.
BlakeTerhune
Ok. I did discuss with my colleague and we also guessing "multi-year grace period" meant. But certainly, we need to plan for the migration in 2026.
BlakeTerhune
Hopefully you got the information you needed. If that answered your question, please mark it as an accepted solution so others visiting this post will know. Thanks!
