Arcgis js 4.19 touch events in hybrid application
1570
06-08-2021 07:16 PM
MoMa
Hi All ,
       I'm new to ArcGIS. Currently trying to build a hybrid prototype application using Vue and capacitor with embedded Arcgis 3D view (SceneView). When trying to interact with the map, the touch events are not working as I would have expected. On Ios/Android if touch is used to try to move the map it snaps into different locations, trying to use pinch to zoom in/out very draggy on Ios and on android works by holding one finder and moving the other.
Is there a way to set those touch events probably in a hybrid app ?
I tried the following
view.navigation.browserTouchPanEnabled = true
setting the navigation properties when initializing the Scene
navigation:  {
  gamepad: {
  enabled: true
 browserTouchPanEnabled: true,
 momentumEnabled: true,
 mouseWheelZoomEnabled: true
added e.preventDefault to pointer-down/enter/leave and move ios:14.6 ,
Android Version: 11
Thanks
AndyGup
One suggestion is to get your basic app running in Vue without capacitor: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-vue-cli. That will help identify any non-Capacitor related performance issues. Also be sure to check out the system requirements documentation: https://developers.arcgis.com/javascript/latest/system-requirements/#hardware-requirements.
