ArcGIS JavaScript: delete all graphics that intersect a polygon?
4088
11-08-2014 06:58 PM
JerryGarcia
How do you manage graphics with the ArcGIS JavaScript API?
Specifically,  I want to delete all graphics that intersect a polygon.  How do I do that?
I have graphics in Feature Layers.
Thanks!
RobertScheitlin__GISP
Jerry,
   You would loop through the Graphics Layers graphics to see if the graphics.geometry is contained in the test polygon. Polygon class has a contain method that take a geometry as a parameter. If the polygon contains the geometry then you use the GraphicsLayers.remove method that take a graphics as its parameter. Hope this helps.
Jerry,
BatbayarJargalsaikhan1
Robert,
is there any sample regarding graphic overlap checking...?!
thanks,
