ArcGis Javascript API draws a polyline, but polyline does't show up.
1661
02-17-2017 09:31 AM
EddyH_
Hi, there,
I am new and just start to learn arcgis Javascript API, I try to draw a polyline on map using following code, but polyline doesn't show up. I have searched solution online and have tried so many ways, but can not make it work. Could you please take a look what is missing? I really appreciate your clue.
Thanks a lot.
Eddy H.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="width=device-width,user-scalable=no">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Maps Electrical Power Distribtution</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.19/esri/css/esri.css">
    <style>
      html, body, #mainWindow {
        font-family: sans-serif;
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #header {
        height: 80px;
        overflow: auto;
        padding: 0.5em;
    </style>
    <script src="https://js.arcgis.com/3.19/"></script>
    <script>
      var map, toolbar, symbol, geomTask;
      require([
  "esri/map",
"esri/toolbars/draw",
"esri/graphic",
"esri/geometry/Polyline",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"dojo/parser",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",  "dojo/domReady!"
], function(Map, Draw, Graphic, Polyline, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,  parser)
parser.parse();
map = new Map("map", {
 basemap: "streets",
 center: [-122.148466, 47.585580],
 zoom: 13
var singlePathPolyline = new Polyline();
singlePathPolyline.addPath([[-123.2, 48.9], [-122.148, 47.585], [-124.50, 49.4]]);
    </script>
  </head>
  <body class="nihilo">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
  </div>
  </body>
</html>
thejuskambi
You are just creating a geometry and not adding it to map. Try this.
<!DOCTYPE html>
<html>
  <head>
    <link rel="stylesheet" href="https://js.arcgis.com/3.19/dijit/themes/nihilo/nihilo.css">
    <style>
        height: 100%;
        width: 100%;
      html, body {
        margin: 0;
        padding: 0;
      #header {
        height: 80px;
        overflow: auto;
        padding: 0.5em;
    </style>
    <script>
      require([ "esri/map",
               "esri/graphic",
               "dojo/parser",
              ], function(Map, Draw, Graphic, Polyline, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,  parser) {
        parser.parse();
          basemap: "streets",
          zoom: 13
        map.on("load", function(){
           var graphic = new Graphic(singlePathPolyline, new SimpleLineSymbol());
           map.graphics.add(graphic);
    </script>
  </head>
  </div>
  </body>
</html>
