ArcGIS Javascript api 3.1 esri undefined error
2407
5
08-14-2012 07:24 AM
KalaivaniNellaiappan
I Have been upgrading the javascript api from 1.5 to 3.1 and having problems with symbols...
I am getting an error
"Microsoft Jscript runtime error: 'esri' is undefined
Also getting a 404 on a particular js file in the api library...
when i debugged in IE,
URL http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/symbol/Symbol.js
Method   GET
Result 404
Type text/html
Received 184 B
Taken  156 ms
Initiator <script>
Any suggestions on this....
Thanks in advance,
Vani
__Rich_
Are you trying to load a locally hosted JS API or the one hosted by ESRI?
The one hosted by esri...
Vani
KellyHutchins
Esri Notable Contributor
Vani,
Can you post the code you are trying to update to 3.1?
Here is the code  that triggers this error
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
var highlightSymbol = new esri.symbol.SimpleFillSymbol();
  highlightSymbol.setStyle(esri.symbol.SimpleFillSymbol.STYLE_SOLID);
  highlightSymbol.setColor(new dojo.Color([255, 255, 0, 0.25]));
  var highlightOutline = new esri.symbol.SimpleLineSymbol();
  highlightOutline.setWidth(2);
  highlightOutline.setStyle(esri.symbol.SimpleLineSymbol.STYLE_DASH);
  highlightOutline.setColor(new dojo.Color([255, 0, 0, 1]));
  highlightSymbol.setOutline(highlightOutline);
  var highlightMarker = new esri.symbol.SimpleMarkerSymbol();
  highlightMarker.setSize(15);
  highlightMarker.setOutline(highlightOutline);
  highlightMarker.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_X);
Thanks Kelly,
Got the answer from John Gravois's reply to the thread " Issues with 3.0 when loading app"...
Actually my code was outisde init...
When i moved it inside init... the issue got resolved...
Vani
