ArcGis corrupts URLs
3502
11
07-29-2022 03:25 AM
Karrok
Karrok
I used a different solution - https://codepen.io/karrok/pen/OJvzeEx
I used
esriConfig.request.interceptors
and fetched tiles on my own
JohnGrayson
Esri Alum
I would recommend against the use of the interceptor for this use case.  Just make sure you specify the parameters correctly and you can just extend the BaseTileLayer, which will help a lot as you try to use other parameters and options from these services.  Using the interceptor to ignore improperly formatted URL parameters might lead to other issues as you try other settings.
