@arcgis/core - Find distance between 2 points
2874
12-04-2022 05:48 AM
MosheLevi
Hi, I am use @arcgis/core package in Angular framework.
I want to calculate distance between 2 points by lat and lng of each point using this package.
I guess that i need something like described in this link. But i don't know how to convert this to the ESM approach.
I guess that i need to import the packages like below, but i don't know how to continue from there.
Any help will be appreciated.
Note that i have no need to draw Map. I need just the calculation.
import * as GeometryService from "@arcgis/core/geometry";
import Point from "@arcgis/core/geometry/Point";
import Map from "@arcgis/core/Map";
import SpatialReference from "@arcgis/core/geometry/SpatialReference";
import DistanceParameters from "@arcgis/core/rest/support/DistanceParameters";
ReneRubalcava
Esri Frequent Contributor
You can use the geometry engine for this, no need to go to the service.
https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-geometryEngine.html#dist...
Here's a sample where it's dynamically imported and used.
https://github.com/odoe/nearby-app-vanilla/blob/main/src/app.ts#L50-L71
MosheLevi
First of all, thank you very much for your response!
Actually, I need to calculate a distance of driving or walking (routing).
From what I understand, the distance  function calculates Planar distance.
I'm sorry I didn't explain it in advance properly
MosheLevi
After more searching, i find out this page witch seems to fit what i need.
I just don't understand what it is the:
portalItem: { id: "69569b47b1e445b8a42ec12feab41ce9" }
I try to replace this to list of stops (that this what i actually need) like this:
    const stops = [
      new Stop({ geometry: { latitude: 32.180763, longitude: 34.929558 } }),
      new Stop({ geometry: { latitude: 31.9339, longitude: 34.8878 } })
    const routeLayer = new RouteLayer({
      stops,
      // portalItem: {
      //   id: "69569b47b1e445b8a42ec12feab41ce9"
But then, the 'routeLayer.routeInfo' is null.
What am i missing?
BlakeTerhune
The portalItem id is the item in Portal for ArcGIS that is the routeLayer, which looks as though you can create it from stops.
// A minimum of two stops is required for routing.
const stops = [
// Create route layer and assign the stops. Only solved routelayers will be rendered.
    stops
ReneRubalcava
Once you create the route layer, you need to call the solve method to get your route and features
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-RouteLayer.html#solve
Then you can get the routeInfo and it will have a totalDistance value you can use
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-RouteInfo.html#total...
