@arcgis/cli create new theme error
1036
05-09-2023 12:10 PM
RobertBossio
When I run command to setup a custom theme (arcgis styles create newtheme), I get error that file/directory does not exist. Is this a known issue, or any solution? Thanks.
estedError: Cannot glob `**/*`: ENOENT: no such file or directory, stat 'C:\Users\<usernamde>\AppData\Roaming\npm\node_modules\@arcgis\cli\node_modules\arcgis-js-api\assets\esri\themes\base'
ReneRubalcava
Esri Frequent Contributor
I broke it. Try with latest 4.25.2 patch just updated. Note, this uses the 4.25 release of the Maps SDK. It will be updated for 4.27 at the next release as some other changes are coming as well.
